11-30-2017, 01:13 PM
Zdravo svima,
Ne mogu nikako da pokrenem WiFi/Bluetooth na RPi 0 W (koji sam kupio na kupujemprodajem). Dobijam sledecu gresku, mozda je neko imao slicna iskustva?
Razumem iz greske da nije dobar firmware ali to je taj i probao sam manuelno da skinem i da ga ubacim (/lib/firmware/brcm/) ali je isti rezultat, evo par detalja:
Takodje probao sam razlicite verzije Raspbian-a ...
Quote:dmesg
[ 10.984916] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[ 10.985315] usbcore: registered new interface driver brcmfmac
[ 11.216829] brcmfmac: brcmf_sdio_verifymemory: Downloaded RAM image is corrupted, block offset is 262144, len is 2048
[ 11.216936] brcmfmac: brcmf_sdio_download_firmware: dongle image file download failed
Quote:uname -a
Linux raspberrypi 4.14.2+ #1057 Fri Nov 24 17:08:22 GMT 2017 armv6l GNU/Linux
Quote:cat /proc/cpuinfo
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 697.95
Features : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2835
Revision : 9000c1
Serial : 00000000167d0cbc
Quote:lsmod
Module Size Used by
cdc_ether 6558 0
r8152 48350 0
brcmfmac 273197 0
brcmutil 9114 1 brcmfmac
cfg80211 542210 1 brcmfmac
snd_bcm2835 23054 0
rfkill 21476 2 cfg80211
snd_pcm 89430 1 snd_bcm2835
snd_timer 22396 1 snd_pcm
snd 59546 3 snd_timer,snd_bcm2835,snd_pcm
uio_pdrv_genirq 3718 0
uio 9901 1 uio_pdrv_genirq
fixed 3033 0
i2c_dev 6674 0
ip_tables 12363 0
x_tables 21353 1 ip_tables
ipv6 397979 18
Quote:hwinfo --short
cpu:
CPU
network:
eth0 Realtek RTL8153 Gigabit Ethernet Adapter
network interface:
lo Loopback network interface
eth0 Ethernet network interface
usb controller:
ARM USB 0
hub:
Linux Foundation 2.0 root hub
VIA VL812 Hub
memory:
Main Memory
unknown:
Broadcom BCM43430 WLAN card
50 GMT 2017 armv6l GNU/Linux
