Raspberry Pi Zero W - ne radi W
Zdravo svima,
Ne mogu nikako da pokrenem WiFi/Bluetooth na RPi 0 W (koji sam kupio na kupujemprodajem). Dobijam sledecu gresku, mozda je neko imao slicna iskustva?
Quote:dmesg
[   10.984916] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[   10.985315] usbcore: registered new interface driver brcmfmac
[   11.216829] brcmfmac: brcmf_sdio_verifymemory: Downloaded RAM image is corrupted, block offset is 262144, len is 2048
[   11.216936] brcmfmac: brcmf_sdio_download_firmware: dongle image file download failed
Razumem iz greske da nije dobar firmware ali to je taj i probao sam manuelno da skinem i da ga ubacim (/lib/firmware/brcm/) ali je isti rezultat, evo par detalja:
Quote:uname -a
Linux raspberrypi 4.14.2+ #1057 Fri Nov 24 17:08:22 GMT 2017 armv6l GNU/Linux
Quote:cat /proc/cpuinfo
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 697.95
Features : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2835
Revision : 9000c1
Serial : 00000000167d0cbc
Quote:lsmod
Module                  Size  Used by
cdc_ether               6558  0
r8152                  48350  0
brcmfmac              273197  0
brcmutil                9114  1 brcmfmac
cfg80211              542210  1 brcmfmac
snd_bcm2835            23054  0
rfkill                 21476  2 cfg80211
snd_pcm                89430  1 snd_bcm2835
snd_timer              22396  1 snd_pcm
snd                    59546  3 snd_timer,snd_bcm2835,snd_pcm
uio_pdrv_genirq         3718  0
uio                     9901  1 uio_pdrv_genirq
fixed                   3033  0
i2c_dev                 6674  0
ip_tables              12363  0
x_tables               21353  1 ip_tables
ipv6                  397979  18
Quote:hwinfo --short
cpu:
                       CPU
network:
  eth0                 Realtek RTL8153 Gigabit Ethernet Adapter
network interface:
  lo                   Loopback network interface
  eth0                 Ethernet network interface
usb controller:
                       ARM USB 0
hub:
                       Linux Foundation 2.0 root hub
                       VIA VL812 Hub
memory:
                       Main Memory
unknown:
                       Broadcom BCM43430 WLAN card
Takodje probao sam razlicite verzije Raspbian-a ...
Nisam obratio pažnju na dijagnostiku kako to izgleda kod mene prilikom boot-a, ali koliko se sećam moraš ručno da podesiš WiFi modul kada se bootuje sistem.
Iz tog razloga moraš da koristiš tastaturu i miša i neki monitor.
Pogledaj ovde: https://www.piborg.org/blog/pi-zero-wifi-bluetooth
Ako ne uspeš, javi se i pošalji mi koju ediciju OS-a tačno koristiš da probam na mom Raspberry Pi Zero W modulu.
Evo kako to izgleda kod mene. Radio je WiFi u startu. Bas pisem sa njega.. Ako ti nesto treba mogu da probam..
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.4.50+ #970 Mon Feb 20 191250 GMT 2017 armv6l GNU/Linux
pi@raspberrypi:~ $ cat /proc/cpuinfo
processor    : 0
BogoMIPS    : 697.95
CPU architecture: 7
CPU variant    : 0x0
CPU part    : 0xb76
CPU revision    : 7
Hardware    : BCM2708
Revision    : 9000c1
Serial        : 0000000008a6e8de
pi@raspberrypi:~ $ lsmod
Module                  Size  Used by
evdev                  11650  6
bnep                   11853  2
hci_uart               21122  1
btbcm                   7885  1 hci_uart
bluetooth             365780  22 bnep,btbcm,hci_uart
brcmfmac              201842  0
brcmutil                9031  1 brcmfmac
snd_bcm2835            23131  1
cfg80211              500739  1 brcmfmac
snd_pcm                95473  1 snd_bcm2835
snd_timer              22556  1 snd_pcm
rfkill                 21397  4 cfg80211,bluetooth
snd                    68400  5 snd_bcm2835,snd_timer,snd_pcm
bcm2835_gpiomem         3759  0
bcm2835_wdt             4133  0
uio                    10230  1 uio_pdrv_genirq
i2c_dev                 6578  0
fuse                   90504  3
ipv6                  367697  36
@npejcic problem je u tome sto uopste ne prepoznaje wifi/bluetooth device (tj nemam wlan0 i hci0). Jel mozes da odradis: cat /proc/cpuinfo?
@gorankg i kod mene je na prethodnom koji sam spalio (ali njega sam kupio novog) Smile
Da li mozete da instalirate hwinfo (sudo apt-get install hwinfo) i odradite hwinfo --short? Hvala.
Imam instaliran hwinfo ali mi ovo čudo ostalo na poslu. Tek sutra ću moći da ti odradim to.
OK, hvala. I mozda ls -la /lib/firmware/brcm/ Smile
(11-30-2017, 03:16 PM)npejcic Wrote: Iz tog razloga moraš da koristiš tastaturu i miša i neki monitor.
Btw, dodavanjem praznog fajla 'ssh' na boot particiju automatski se dobije remote pristup tako da moze i preko mreze/terminala da se podesava.
pi@raspberrypi:~ $ hwinfo --short
cpu:
                       CPU
keyboard:
                       Compaq KU-0133 Easy Access Interner Keyboard
mouse:
                       Logitech USB Optical Mouse
network interface:
  wlan0                WLAN network interface
disk:
  /dev/ram0            Disk
  /dev/ram1            Disk
  /dev/ram2            Disk
  /dev/ram3            Disk
  /dev/ram4            Disk
  /dev/ram5            Disk
  /dev/ram6            Disk
  /dev/ram7            Disk
  /dev/ram8            Disk
  /dev/ram9            Disk
  /dev/ram10           Disk
  /dev/ram11           Disk
  /dev/ram12           Disk
  /dev/ram13           Disk
  /dev/ram14           Disk
  /dev/ram15           Disk
  /dev/mmcblk0         Disk
partition:
  /dev/mmcblk0p1       Partition
  /dev/mmcblk0p2       Partition
hub:
                       O2 Micro Hub
                       Linux 4.4.50+ dwc_otg_hcd DWC OTG Controller
                       Genesys Logic USB2.0 Hub
memory:
                       Main Memory
unknown:
                       O2 Micro Unclassified device
pi@raspberrypi:~ $
pi@raspberrypi:~ $
pi@raspberrypi:~ $
pi@raspberrypi:~ $
pi@raspberrypi:~ $ ls -la /lib/firmware/brcm/
total 4268
drwxr-xr-x  2 root root   4096 Mar  3  2017 .
drwxr-xr-x 12 root root   4096 Mar  3  2017 ..
-rw-r--r--  1 root root  96224 Jun  7  2016 bcm43xx-0.fw
-rw-r--r--  1 root root    180 Jun  7  2016 bcm43xx_hdr-0.fw
-rw-r--r--  1 root root 397312 Jun  7  2016 brcmfmac43143.bin
-rw-r--r--  1 root root 385067 Jun  7  2016 brcmfmac43143-sdio.bin
-rw-r--r--  1 root root 455745 Jun  7  2016 brcmfmac43241b0-sdio.bin
-rw-r--r--  1 root root 403855 Jun  7  2016 brcmfmac43241b4-sdio.bin
-rw-r--r--  1 root root 253748 Jun  7  2016 brcmfmac4329-sdio.bin
-rw-r--r--  1 root root 222126 Jun  7  2016 brcmfmac4330-sdio.bin
-rw-r--r--  1 root root 451566 Jun  7  2016 brcmfmac4334-sdio.bin
-rw-r--r--  1 root root 569291 Jun  7  2016 brcmfmac4335-sdio.bin
-rw-r--r--  1 root root 219557 Jun  7  2016 brcmfmac43362-sdio.bin
-rw-r--r--  1 root root 369576 Jun  7  2016 brcmfmac43430-sdio.bin
-rw-r--r--  1 root root   1108 Jun  7  2016 brcmfmac43430-sdio.txt
-rw-r--r--  1 root root 507752 Jun  7  2016 brcmfmac4354-sdio.bin
pi@raspberrypi:~ $
Hvala @gorankg. Da li mozda mozes da mi zipujes i posaljes /lib/firmware/brcm/?
Poslao, proveri.
Stiglo je hvala, javicu rezultate kasnije. Btw Guglanjem za "Broadcom BCM43430 WLAN card" dolazim do gomile postova po forumima sa istim problemom za razlicite platforme i bez konkretnog resenja ...
Sta vam tacno vrati:
Quote:pi@raspberrypi:~ $ cat /proc/device-tree/model
Raspberry Pi ? Rev 1.1
I sta dobijate kada uradite ovo:
pi@raspberrypi:~ $ sudo vcgencmd otp_dump
08:00000000
09:00000000
10:00000000
11:00000000
12:00000000
13:00000000
14:00000000
15:00000000
16:24280000
17:1020000a
18:1020000a
19:ffffffff
20:ffffffff
21:ffffffff
22:ffffffff
23:ffffffff
24:ffffffff
25:ffffffff
26:ffffffff
27:00005050
28:167d0cbc
29:e982f343
30:009000c1
31:00000000
32:00000000
33:00000000
34:00000000
35:00000000
36:00000000
37:00000000
38:00000000
39:00000000
40:00000000
41:00000000
42:00000000
43:00000000
44:00000000
45:00000000
46:00000000
47:00000000
48:00000000
49:00000000
50:00000000
51:00000000
52:00000000
53:00000000
54:00000000
55:00000000
56:00000000
57:00000000
58:00000000
59:00000000
60:00000000
61:00000000
62:00000000
63:00000000
64:00000000
65:00000000
66:00000000
pi@raspberrypi:~ $
Hvala Smile
Raspberry Pi Zero W Rev 1.1pi@raspberrypi:~ $ sudo vcgencmd otp_dump
08:00000000
09:00000000
10:00000000
11:00000000
12:00000000
13:00000000
14:00000000
15:00000000
16:24280000
17:1020000a
18:1020000a
19:ffffffff
20:ffffffff
21:ffffffff
22:ffffffff
23:ffffffff
24:ffffffff
25:ffffffff
26:ffffffff
27:00005050
28:08a6e8de
29:f7591721
30:009000c1
31:00000000
32:00000000
33:00000000
34:00000000
35:00000000
36:00000000
37:00000000
38:00000000
39:00000000
40:00000000
41:00000000
42:00000000
43:00000000
44:00000000
45:00000000
46:00000000
47:00000000
48:00000000
49:00000000
50:00000000
51:00000000
52:00000000
53:00000000
54:00000000
55:00000000
56:00000000
57:00000000
58:00000000
59:00000000
60:00000000
61:00000000
62:00000000
63:00000000
64:00000000
65:00000000
66:00000000
pi@raspberrypi:~ $
Hvala Gorane i u moje ime jer ja danas ne stigoh da pošaljem test razultate Sad
