07-19-2015, 08:55 PM
Pozdrav svima,
da li je neko imao priliku da proba ovo novo cudo microchipa i kakvi su vam utisci?
Taman se naviknes na MPLAB pa na MPLABX pa sa C32 na XC32 a sada opet izmena.
Pre si bar imao iluziju da znas kako ce program da radi a sada ko zna ste se tu desava.
Izgleda da su sada mikrokontroleri isuvise mocni pa svako moze da priusti da na racun optimizacije dobije neke druge stvari.
Quote:MPLAB® Harmony is a flexible, abstracted, fully integrated firmware development platform for PIC32 microcontrollers. It takes key elements of modular and object oriented design, adds in the flexibility to use a Real-Time Operating System (RTOS) or work without one, and provides a framework of software modules that are easy to use, configurable for your specific needs, and that work together in complete harmony.
MPLAB® Harmony includes a set of peripheral libraries, drivers and system services that are readily accessible for application development. The code development format allows for maximum re-use and reduces time to market.
