05-23-2018, 08:43 PM
Zdravo svima,
Pokusavam da podesim linker skript tj konkretno sekciju za inicijalizaciju steka ali izgleda da ne znam kako. Ovo su trenutne i zeljene vrednosti:
Pretpostavio sam da Reset_Handler nije dobar i probao sam svasta sa njim (ldr r0/r1/sp, =_estack) ali bezuspesno.
Kao sto stoji u naslovu koristim AC6 System Workbench i STM32F303VCTx sa StdPeriph FW v1.1.0.
Da li imate neki savet kako ovo da resim?
Hvala,
Ivan
Quote:/* Entry Point */
ENTRY(Reset_Handler)
/* Highest address of the user mode stack */
_estack = 0x2000A000; /* end of RAM */ <- Ovo zelim da promenim u 0x2001A000
/* Generate a link error if heap and stack don't fit into RAM */
_Min_Heap_Size = 0x200; /* required amount of heap */
_Min_Stack_Size = 0x400; /* required amount of stack */
/* Specify the memory areas */
MEMORY
FLASH (rx) : ORIGIN = 0x8000000, LENGTH = 256K
RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 40K <- Ovo zelim da promenim u 0x20010000
CCMRAM (rw) : ORIGIN = 0x10000000, LENGTH = 8K
/* Define output sections */
SECTIONS
/* The startup code goes first into FLASH */
.isr_vector :
. = ALIGN(4);
KEEP(*(.isr_vector)) /* Startup code */
. = ALIGN(4);
} >FLASH
/* The program code and other data goes into FLASH */
.text :
. = ALIGN(4);
*(.text) /* .text sections (code) */
*(.text*) /* .text* sections (code) */
*(.glue_7) /* glue arm to thumb code */
*(.glue_7t) /* glue thumb to arm code */
*(.eh_frame)
KEEP (*(.init))
KEEP (*(.fini))
. = ALIGN(4);
_etext = .; /* define a global symbols at end of code */
} >FLASH
Quote:Reset_Handler:
/* Copy the data segment initializers from flash to SRAM */
movs r1, #0
b LoopCopyDataInit
Hvala,
Ivan
