06-02-2020, 11:19 AM
Main Chipset
ASUS AV200 High-Definition Audio Processor (Max.
192KHz/24bit)
Audio Processor
Video Processor
ASUS Splendid HD Video Processor
TI Burr-Brown PCM1796 *1 on AV card;
*3 on H6 DAC Extension Board
(123dB SNR, Max. 192kHz/24bit)
24-bit D-A Converter of Digital Sources:
24-bit A-D Converter for Analog Inputs: Cirrus-Logic CS5381* 1 120dB SNR, Max. 192kHz/24bit)
Output Audio OPAs Swappable DIP-typed NS LM4562 *4 (Ultra low THD+N~
0.00003%)
Analog Audio Performance
Output Signal-to-Noise Ratio (A-Weighted): Up to 120 dB for all channels
Input Signal-to-Noise Ratio (A-Weighted):
Output Total Harmonic Distortion + Noise at
1KHz: Up to 118 dB
Up to 0.0004% (-108dB)
Input Total Harmonic Distortion + Noise at 1KHz: Up to 0.0003% (-110dB)
Frequency Response (-3dB, 24-bit/96kHz input ): <10Hz to 46kHz
DAC Cross-talk at 1KHz: Down to -130 dB
ADC Cross-talk at 1KHz: Down to -115dB
-2.2 Vrms (6.22 Vp-p) for output
-2.0 Vrms (5.65 Vp-p) for input
Output/Input Full-Scale Voltage
Bus Compatibility
-PCI Express Rev.1.0a specification compatible
-Max. full 2.5Gbps bandwidth per direction and optimized
latency for high-definition audio processing
-Compatible with X1, X4, X8, X16 PCI Express slots
Interesuje me misljenje o istoj i da li bi vredelo menjati OP ampove posto su na podnozju
Koliko bi vredela neka merenja ala Braca
HVALA na misljenju
192KHz/24bit)
Audio Processor
Video Processor
0.00003%)
1KHz: Up to 118 dB
Bus Compatibility
HVALA na misljenju
