Ponesi na skup da vidimo kako to radi.
Obavezno. Smile
ha-opasno! Smile
TDA jel to Dso138 ili neki drugi ??? inace lepa i korisna spravica.
Ej Bože. 25$. Čoveče. Smile
(05-04-2017, 05:47 PM)Dackotronic Wrote: TDA  jel to Dso138 ili neki drugi ??? inace lepa i korisna spravica.
DSO150
(05-04-2017, 02:44 PM)TDA Wrote: Stigao pre sat vremena.
Sklopio sam ga, uradio kalibraciju i radi za sve pare! Smile
http://www.ebay.com/itm/Orignal-Tech-DS0...SwzaJYBIZc
Odlična stvar za poneti na teren u kutiji za alat.
Nek te lepo sluzi. Ajd ga malo testiraj, pa okaci kakvi su utisci/karakteristike. Jel napajanje baterijsko ili preko adaptera?
Ovde su neki detalji koji su navedeni u prezentaciji:
Features:
Kits using ARM Cortex-M3 processor (STM32F103C8), and includes a 2.4-inch color TFT display can be used as ARM test development board.
Circuit is simple and the kit is inexpensive
Characteristics of indicators:
Supply voltage: DC 9V
Maximum real-time sampling rate: 1Msps
Accuracy: 12Bit
Sampling buffer depth: 1024 bytes
Analog bandwidth: 0 - 200KHz
Vertical Sensitivity: 5mV / Div - 20V / Div
Adjustable vertical displacement, and with instructions
Input impedance: 1MΩ
Maximum input voltage: 50Vpp (1: 1 probe), 400Vpp (10: 1 probe)
Coupling modes: DC / AC / GND
The horizontal time base range: 10μs / Div - 50s / Div (1-2-5 progressive manner)
With automatic, regular and one-shot mode, easy to capture the moment waveform
Available rising or falling edge trigger
Adjustable trigger level position, and with instructions
Observable previous trigger waveform (negative delay)
Can freeze at any time waveform display (HOLD function)
Comes 1Hz /3.3V square wave test signal source
Testirao sam ga na SMPS adapteru od 9V. Na pločici postoji i priključak za baterijsko napajanje, ali u samom kućištu nema prostora za samu bateriju.
Do sada sam stekao utisak da se može u potpunosti koristiti kao zamena za običan osciloskop za neka osnovna očitavanja.
Probaću ovih dana da ga malo namučim.
Super izgleda uredjaj, samo u tvom slucaju, nema ziroskop za teren... medj oblake...
U dobrom si društvu - hvale ga i ovde:
http://www.diyaudio.com/forums/lounge/14...-9220.html
Neka te lepo i dugo služi!
Hvala. Dobro je znati da nisam pogrešio u izboru.
Isti je mikrokontroler kao na DSO138 samo je bolja varijanta jer su skinuli one prekidače.
Ima par dana došla mi ova mašina, HP 334A, nisan moga odolit, odlično očuvan izvanka, a unutra je apoteka.
Prova san mirit izoblićenje sa GF, i usporedit sa Arta i E-MU 0202, na 1k i 10k i ispalo je približno isto. Voltmetar je točan, tako da san zadovoljan, jel nisan zna jel radi ili ne kad san ga kupija.
Neznan kolko ću ga koristit, al vridi ako ništa za gledanje i inspiraciju u radioni, slab san na te stare instrumente.
Malo me iznenadija, u glavi san ga skalira na osnovu GF HP 3310B, mislin se oba imaju onaj kolut, pa san pritpostavija da je istih dimenzija, ali ovaj 334 je ogoman uređaj....
Da se primjetit da jedino falu dva originalna botuna selektora frekvencije i funkcije uređaja, nabavija san neke od HP-a, al su dosta manji.... Ako neko ima nešto slićno volija bi ga kompletirat...
[Image: 20170429_102150.jpg]
[Image: IMG-20170428-_WA0005.jpg]
[Image: IMG-20170428-_WA0007.jpg]
[Image: IMG-20170504-_WA0021.jpg]
[Image: IMG-20170504-_WA0025.jpg]
Dobra masina... Smile
(05-04-2017, 10:03 PM)pinco Wrote: Ima par dana došla mi ova mašina, HP 334A, nisan moga odolit, odlično očuvan izvanka, a unutra je apoteka.
Neka te dobro služi!
Imao sam ga u rukama nedavno kada sam preuzimao moje instrumente, dali bi ga sigurno za male pare, ali ga nisam uzeo. Razlog je što u originalnoj izvedbi ne ide dovoljno duboko u THD smislu, a poboljšati ga nije ni najmanje lako:
http://www.tronola.com/moorepage/334.html
Ti stari instrumenti su i meni slabost, ali ovoga puta sam se nekako uspeo odbraniti.
Nabavio sam isti takav, sad ramisljam kako da mu ugradim neku Li-ion bateriju... Wink
Inace za te pare je sasvim OK...
Vrlo simpaticna spravica taj mini DSO, sigurno vredi sve te novce!
Za napajanje, ima ovaj jeftin punjac za Li-ion baterije (linkujem prvi koji sam nasao, ima ih svuda), puni se preko USB, u kolu baterije ima strujna+naponska zastita, sve kako treba.
https://de.aliexpress.com/store/product/...35214.html
Uz to uzeti i neki Boost pretvarac, to podigne napon sa 3.7V na 9V i to je to.
http://www.ebay.com/itm/DC-DC-Converter-...0011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D40130%26meid%3D8e7dc0a6d3e24ab7a69ca780cf67dae7%26pid%3D100011%26rk%3D1%26rkt%3D6%26sd%3D371086462802
Izmerite potrosnju tom mini DSO na 9V, ne verujem da ce biti vise od 20-30mA, shodno tome izaberite Boost pretvaracki modul sa najvecom radnom frekvencijom jer bi trebali da budu "tiši" a i ako nisu lakse se filtriraju sa malim dodatnim L/C.
Da sam na vasem mestu, uzeo bih po primerak svih onih maleckih DC/DC pretvaraca i probrao primerke koji najbolje rade.
PS: prakticno je da se drzite USB i 5V napajanja za portable sprave jer sada imaju povoljno gotova bateriska pakovanja u raznim kapacitetima i opcijama, ja sam uzeo ovo, to brale moze 5x da napuni telefon i jedno dva puta tablet racunar, ovaj DSO bi sa tim radio jedno mesec dana bez prekida, jos ova baterija ima dva USB izlaza taman za jos jedan DSO tj drugi kanal Big Grin
https://uae.souq.com/ae-en/proda-dual-do...7727349/i/
PS2: Al' ste me zaludeli sa ovim mini DSO, pa ovo se isplati ugraditi kao instrument na prednju plocu nekog uredjaja, recimo umesto VU metra ugradi se dva DSO za levi i desni kanal Big Grin ili kao U/I metar u PSU ... pa toliko kosta jedan dobar analogni instrument koliko ceo ovaj mali DSO! Jos kad bi imao source code za Firmware da se malo "dohakuje", ihhh kako bi to bilo dobro, a odprilike znam i koja je ekipa radila SW, vrlo verovatno da je unutra STM32 ili neki slican ARM procesor ... Mislim kada je "nastradao" Rigol (eno pokrenuli ceo Linux na njemu, sta ce tek da mu rade mozete misliti, ja cekam dan kada cu moci na Rigol DSO da pokrenem svoju neku custom APP, a blizi se taj trenutak!), za ovaj malecki DSO je glupo da ne objave source Smile
DSO138 je najeftinija varijanta za razvojni sistem za STM32.
Ima ovde diskusija na temu sa osciloskopom:
http://stm32duino.com/viewtopic.php?f=19&t=107
http://stm32duino.com/viewtopic.php?f=19&t=1847
Sors postoji, video sam ga, samo još da nađem gde Huh
Edit: Našao!
http://linksprite.com/wiki/index.php5?ti...38_DIY_Kit
Verovatno ima i ovde pošto su ga oni napravili:
http://www.jyetech.com/index_en.php
Probao sam ga sinoć na klasičnoj 9V bateriji.
Radi sasvim solidno.
Razmišljao sam da spojim 3 LiPo baterije iz tableta, mobilnih ili lapropa i uradim neki pretvarač na 9V.
Jasno mi je sve, al nisan moga odolit, dobra stvar šta se može koristit ka mV, 0,1mV-300V FS, mislin 3Mhz, neću po njemu radit nikakve preinake. Bilo bi mi ža, neka ostane u originalnome stanju, fascinantno je vidit kvalitetu izrade. Taman da se nikad nebude koristija lipo izgleda, samo je malo velik....
Ja kad sidnen u svoju malu radionicu, bacin pogled na te instrumente, odma mi se raspoloženje popravi Smile
Users browsing this thread: 90 Guest(s)
