Lsusb rezultat
Code:
Bus 001 Device 002: ID 0ac8:3420 Z-Star Microelectronics Corp. Venus USB2.0 Camera
dmesg
Code:
[  163.922857] usb 1-1: new high-speed USB device number 2 using ehci-pci
[  164.248243] usb 1-1: New USB device found, idVendor=0ac8, idProduct=3420
[  164.248250] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  164.248254] usb 1-1: Product: Webcam gadget
[  164.248257] usb 1-1: Manufacturer: Linux Foundation
[  164.353106] media: Linux media interface: v0.10
[  164.377587] Linux video capture interface: v2.00
[  164.449434] uvcvideo: Unknown video format 35363248-0000-0010-8000-00aa00389b71
[  164.449439] uvcvideo: Found UVC 1.00 device Webcam gadget (0ac8:3420)
[  164.458167] usbcore: registered new interface driver cdc_ether
[  164.462118] input: Webcam gadget as /devices/pci0000:00/0000:00:11.0/0000:02:03.0/usb1/1-1/1-1:1.2/input/input6
[  164.462473] usbcore: registered new interface driver uvcvideo
[  164.462474] USB Video Class driver (1.1.1)
[  164.489903] rndis_host 1-1:1.0 usb0: register 'rndis_host' at usb-0000:02:03.0-1, RNDIS device, 3e:5f:76:b1:fc:eb
[  164.491036] usbcore: registered new interface driver rndis_host
[  164.496670] cfg80211: World regulatory domain updated:
[  164.496672] cfg80211:  DFS Master region: unset
[  164.496673] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[  164.496674] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[  164.496675] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[  164.496676] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[  164.496677] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[  164.496678] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[  164.496679] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[  164.496680] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[  164.496680] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[  164.504092] usbcore: registered new interface driver rndis_wlan
[  164.521096] rndis_host 1-1:1.0 ens35u1: renamed from usb0
[  164.544946] IPv6: ADDRCONF(NETDEV_UP): ens35u1: link is not ready
[  201.184736] perf interrupt took too long (2568 > 2500), lowering kernel.perf_event_max_sample_rate to 50000
Ako ima neko neku ideju sta proveriti i kako proveriti
Uspeo sam da ga dibijem kao network adapter i dobio ip adresu i uspevam da se spojim preko ssh ali na zalost lozinka nije poznata a trazi je : )
Code:
ens35u1   Link encap:Ethernet  HWaddr 3e:5f:76:b1:fc:eb
          inet addr:10.42.0.1  Bcast:10.42.0.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:34 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:9968 (9.9 KB)
Code:
PING 10.42.0.1 (10.42.0.1) 56(84) bytes of data.
64 bytes from 10.42.0.1: icmp_seq=1 ttl=64 time=0.020 ms
64 bytes from 10.42.0.1: icmp_seq=2 ttl=64 time=0.062 ms
64 bytes from 10.42.0.1: icmp_seq=3 ttl=64 time=0.034 ms
gde naci lozinku? : )
Odlično!
Probaj klasiku 0000, 1234 ili mechanic ili model...
Ili koristiti brutal force ssh program pod linuxom Smile
Nije to moguce bez iscitavanja sadrzaja configuracionog fajla iz interne memorije : ) Kad bi je otvorio kameru onda bi video dali je uopste moguce bilo sta uraditi, tu je verovatno neki mcu koji u sebi ima mali linux pa verovatno i nije moguce ga spojiti na bilo sta da bi se to iscitalo. Poslao sam poruku prodavcu i pitao ga da mi da lozinku heh ako bude hteo da je da, to bi bilo previse lako za kloniranje da bi bilo uopste istinito, nisu Kinezi naivni sto se toga tice pa su to zastitili maksimalno od moguceg kloniranja uredjaja : )
Bar kad bi nasao firmware tool za fw update kamere ali pretrazio sam nema toga ni u naslovu nigde : ) Usb im je nacin za fw update pa bi trebalo da postoji lozinka u fw alatu ali dzabe kad ga nema za ovu kameru, tu bi se pronasla lozinka : )
Ja bi iako teska srca otvorio oprezno kameru i poslikao pcb i senzor i spojio rx i tx i gnd na terminal da iscitas preko terminala boot driver gdje ce da ti pise driver za senzor kamere, ovako kako trazis preko usb ti je lov u mutnom.
Takvo kuciste fino iskoristis kasnije za rpi kameru koju ugradis u to kuciste i napises svoj gui pod linuxom..i onda imas finu kameru rpibu novom kucistu Smile
Otvoris kameru i vidis kao i svi mi sto je unutra, jer sa kamere sam imao visoka ocekivanja a slike i manjkavost opcija su male....ovako otvoris i nadogradis svoj linux sa driverom i isprogramiras svoj gui sa brdo opcija koje ti fale...mozda je unutra rpi kamera..ko zna?
Nebi ja bas da otvaram kameru za koju nisam siguran kako se otvora, druga je prica da su vidljivi srafovi kao sto nisu onda bi vec mogao da je otvaram, ali ovako sto bi unistio kameru koja radi dobro svoj posao, samo mi fali dobro svetlo, moja soba je malo mracnija i nemam podjednako svetlo svuda u prostoru kao kod ddanijel, kod njega se jasno vidi da bi njegova kamera odlicno radila i bez svetla ispod kamere, pa tako kad i kod mene dodje svo potrebno svetlo bice to dobra kamera za rad! Nemojte da gledate one skrinshotove, nije takva na ekranu, dobra je to kamera. Gledaj, niko ne garantuje da u kameri postoje TX i RX, takodje niko ne garantuje i da je u ramdisku omogucen serijski izlaz cak i u slucaju da postoje ovi pinovi, tako da je necu otvarati nema potrebe da to radim. Gore iz prilozenog moze se zakljuciti da ima omogucen na moje iznenadjenje RNDIS pa cak i svoj SSH secure server sto je znak da je u pitanju nesto ozbiljnije u kameri neki verovatno Linux operativni sistem. Mene samo zanima koji je senzor unutra nista vise od toga, takodje me zanima zasto te kamere nema na Mechanic sajtu a ima isti naziv kao da su je pravili Mechanic
Ok, posteno.
Ako mozes napraviti par fotki smartphonom ekrana da vidimo razliku...jer ako na monitoru imas ovalitetu ko sto ddanijel ima onda je to to.
Ove jpeg savene u kameri su zrnaste...
Hocu cim nabavim svetlo i za policu svetlo i za kameru, nema smisla bez toga da pravim snimak. I ovo je  zanimljivo sto pise na poledjini kutije u vezi senzora , takodje nema link do sajta proizvodjaca niti koji je proizvodjac u pitanju, treba dobro obratiti paznju i ne verovati sta pise na Aliju, ocigledno je da nije Sonijev senzor i ko zna koji senzor i koliko piksela ima. A sad cu lepo i da slikam i da im posaljem link od koga sam kupio kameru i poslati na https://www.mechanichk.com/ da vidim zasto te kamere nema na njihovom sajtu
Dali je ovo najbolja mechanic kamera sa imx334 sony senzorom i original je? Pise da je 8,32Mpixela....sto se misli o njoj? Ima puno reviewa nanetu forumima i yoputube...
https://www.mechanichk.com/mechanic-dx-4...75193.html
Meni je zao sto nisam ovu uzeo https://www.mechanichk.com/rx-510-hd-hdm...40693.html a nju sam dugo gledao da kupim i to preko LCSC ali sam zakasnio jer su sklonili tog proizvodjaca sa spiska, tamo je sigurno bila original dok vec na Aliju postoje sa drugacijim rasporedom teksta pa je vrlo moguce da su fake! Vrlo je moguce da su proizvodjaca izbacili sa spiska jer su se pocele pojavljivate fake Mechanic kamere kao mozda ova sto sam kupio., poslao sam im mejl da mi kazu sta sam ja to kupio i dali oni to proizvode.
Ova bi trebala da je najbolja iz njihove ponude https://www.mechanichk.com/mechanic-dx-4...82291.html , ovu sto si okacio je mini verzija te
Znas sta mene zanima, po cemu si zakljucio da je ova kamera sto sam je kupio best buy, gde si vedeo taj review imas li link do njega?
Nasao sam link, ti si spominjao Nortbridgefix, pomesao sam ja nesto, bilo je samo spomenuto ovo https://forum.yu3ma.net/thread-2772-post...#pid129222 i tu sam se upecao misleci da je to kamera sa Sonijevim senzorom i odnos cena-kvalitet vrlo jeftina ali se ispostavlja da je to fake, bas me zanima sta ce mi odgovoriti Mechanic : ) Ako kazu da to nije njihov proizvod definitivno cu da je otvorim i vidim sta je unutra.
Savane izvini ako sam te naveo pogresno da kupis tu kameru.
Ja sam gledao kamere i northridgefix ali ta mi je na papiru izgledala top i mislio sam da je original ali vidim da nije posto ima malo menu opcija i kompresija slike na sd karticu.
Pogledaj jos sto se nudi od kamera pa postavi link...ja sam uspio aktivirat novu karticu za aliexpress pa cu onda narucit onu koja je najbolja za ulozen novac..zasada imamo tu mechanic kameru i ima jos koja koju si gledao a da je super kamera?
Savane sto mislis o ovoj kameri? Pise da ima sony imx senzor sto je trebala tvoja kamera da ima.
Just found this amazing item on AliExpress. Check it out!
€192.62 5%OFF | RisingCam 4K UHD 30fps bulit-in SONY imx678 1/1.8" sensor HDMI and USB output digital industrial microscope camera with C mount
https://a.aliexpress.com/_EQEaabP
Pogledaj gui za podesavanje kamere, ima brdo opcija...jest duplo skuplja od tvoje kamere ali ako se uhvati koji popust i original je vrijedno je novca...ovo mi izgleda da je original jer su senzori imx koji je u kameri oko$200
Nisi ti kriv nego ja sto sam se zaleteo! Sad tek vidim da je proiizvodjac te kamere KOOSTR a ne Mechanic, model se zove "MECHANIC MOS 4K/ 4K Pro" , sve su to trikovi za prodaju i stvarno treba otvoriti oci sirom kada se kupuje roba preko Ali pogotovo ne obracati puno paznje na placene YT reviewe nego to je macka u dzaku sta god tamo da kupis. Bolje je kupiti preko neke Firme recimo prek Mouser ako imaju kamere za prodaju, tamo ces bar znati tacno ko je proizvodjac i koji je senzor u kameri. Javio mi se prodavac u vezi lozinke kaze "I'll go make sure" proverice pa ce mi javiti. Ne znam sta da ti kazem u vezi kamere, ocigledno je to da u rangu 100eur tesko da se moze ocekivati nesto izuzetno dobro, koliko para toliko muzike uvek bilo. Tako da ne ocekuj da ces moci da nadjes kameru za 100-150eur da se picino oko moze videti na ekranu, ali ocekuj da sa bilo kojom koju kupis ces moci da radis fino pa recimo i sa ovakvom kakvu sam ja kupio
(01-24-2024, 04:53 PM)ronovar Wrote: Savane sto mislis o ovoj kameri? Pise da ima sony imx senzor sto je trebala tvoja kamera da ima.
Sve je to pitanje! I na ovoj prodavac tvrdi da je isti taj SONY imx678 senzor, mozda jeste a mozda i nije, isto i na mojoj kameri mozda jeste a mozda i nije, ko bi to znao. Mislim da kameru treba kupiti od pouzdane firme i nikako preko Ali! Mora da se zna proizvodjac i da postoji link do proizvoda koju nudi isti taj proizvodjac, recimo ova mechanic 4k pro ima proizvodjaca sa imenom KOOSTR ali ajde nadji link do te kamere pa nema cak ni link do proizvodjaca : )
Na Ali tvrdi da je senzor SONY imx678 a video si sliku sto sam okacio i sta pise na kutiji koji je senzor na kameri? Tako da nista od Ali kada se kupuju ozbiljne stvari, sve je to tamo neozbiljno.
A pogledaj imx334 cijenu kamere, ima da je original a isto kuciste kao ona gore imx678, a vidi video za 300 eura ovu kakva ostrina i zoom i bogati gui za podesavanje kamere...
€325.70 22%OFF | Autofocus SONY IMX334 4K HDMI USB Phone SMD Repair Industrial Measuring Video Microscope Camera For Stereo Trinocular Microscope
https://a.aliexpress.com/_EyNIxHf
Ni ja nisam vise siguran sta je pravi izbor za kupiti sto se kamere tice, ako bas hoces nesto originalno i sigurno originalno pogledaj ovde https://eu.mouser.com/c/optoelectronics/...a-modules/ ili direktno od poznatog proizvodjaca koji ima sajt i koji ima proizvod na svom sajtu, sve te kamere od nepoznatih proizvodjaca ne treba gledati. Ok Eakins je poznat brend mada treba uzeti sa rezervom dali je to original jer je proizvod na Aliexpres a ne sa originalnog Eakins sajta. Pogledaj i video iz prvog posta ako nisi odgledao, koliko je dobra slika i sa tom mini kamericom, bar je provereno IMX u pitanju jer je kupljena kod Galago koji je zastupnik za Rpi i taj ti sigurno nece podvaliti nesto trece kao ovaj sto prodaje 4k pro. Ja inace retko kupujem sa Ali, ali ne mora uvek da znaci da ne valja ima tamo dobrih stvari ali dobro razmisliti pre kupovine!
Pogledaj recimo ovo https://www.aliexpress.com/item/1005001864859010.html i uporedi sa onom originalnom RX-510 ! Pogledaj koji je brand ove, nije Mechanic bez obzira sto su vrlo slicne, brand je DIYPHONE , vrlo vesto uradjeno da lici na originalnu cak ni isti brend nije i jasno pise da nije, znaci cetvoro ociju treba otvoriti pre kupovine na Aliexpress!!! Zato ja nisam kupio RX-510 jer sam sumnjao da su fake sto tek sad vidim da stvarno jesu fake a nisam stigao na vreme da kupim sa LCSC a bilo ih je dorektno odatle za kupiti original. Mechanic Company u prevodu moze da znaci mehanicka kompanije a ne i Mechanic kompanija.
i oni su se time ogradili da mogu da je prodaju na legalan nacin bez obzira sto je fake i sto vrlo podseca na original.
Gledam kamere vec duze vrijeme, mislim da cu ovu kupiti ali prije cu kontaktirat prodavaca da vidim sto kaze oko senzora i originala i ako moze da mi posalje slike iznutra kutije pcb i kamere...
€374.44 15%OFF | RisingCam Auto Focus 4K UHD 60fps HDMI and USB output digital industrial microscope camera autofocus with SONY imx334 sensor
https://a.aliexpress.com/_EGnKzbb
10/2 je kineska nova godina pa mislim da ce biti oko 30 eura kuponi....
Slike tj video za tu kameru su impresivni ali pitanje je jel to ta kamera ili neka druga da se privuku kupci.
Inace skuzio sam da cim je oznaka IMX senzora manja to je kvalitetniji senzor prema kinezima...
Recimo od najlosijeg do najvoljeg...
IMX678 IMX385 IMX334 ...
Users browsing this thread: 67 Guest(s)
