Ovo je antena za?
Zdravo drugari,
Da li možda imate predstavu koja je ovo tehnologija komunikacije, na osnovu antene? Hvala.
[Image: attachment.php?aid=33864]
Izgleda kao WI-Fi ruter od prije desetak godina.
Jeste WiFi, evo ga model: https://www.sintroncorp.com/abox-5200g4.html a inace to je ovo: https://rs.n1info.com/Vesti/a623924/Nace...lovom.html
Hehe, PC masina izuva ... nema cena ...
Quote:Fanless AI Box Computer: ABOX-5200G4 from Sintrones
A certified artificial intelligence computer ABOX-5200G4. Designed for automatic license plate recognition.
Fanless AI Box Computer: ABOX-5200G4 from Sintrones – A certified artificial intelligence computer. Together with an installed camera, ABOX-5200G4 captures license plate images, analyzing and calculating the images to match vehicle identities through intelligent image analysis. Furthermore, ABOX-5200G4 can transmit the analyzed information to police administration to enable indicated action.
The solution enables real-time image analysis and data transmission, providing accurate and effective information for law enforcement.
Intel GEN 8th 6 Cores i7-8700T
NVIDIA® GeForce GTX 1060 GPU
Support 1280 CUDA Cores
8 x GPI and 4 x GPO and 3 x RS-232/422/485
Dual Hot Swappable SATA Storage RAID 0,1,5
9-48V DC Input and Operating Temp.: -40~60°C
10 x GbE LAN (Optional for 8 x PoE)
[Image: attachment.php?aid=33869]
Otišlo sve u k**** kada policija upotrebljava ovakvu bijesnu tehnologiju umjesto da služi nečem korisnom....
[Image: attachment.php?aid=33871]
@mikikg ovaj model nema slot za SIM karticu. Zato mi nije jasno čemu im služi WiFi, jer bi navodno trebali da šalju slike u realtime Pošti...
OK, WiFi im je za internu mrežu (attack vector no. 1), i imaju verovatno dodatni hardver za 3G/LTE (3 x Full Mini-PCle Slots and 1x M.2 A-E Key 2230/3030 slot (2 x SIM Card Sockets for 3G/LTE)).
Sa ovim PC je manje vise sve jasno, ali me ovo buni, sta je unutra? Smile
Rezervni tocak sigurno nije ... akumulator isto nije jer je on na zadnjem sedistu ... Smile
Kutija je zabravljena sa velikim "zutim" katancem Smile
[Image: attachment.php?aid=33880]
[Image: attachment.php?aid=33881]
Ovde na drugoj fotki je interesatno sto je prikljucen samo jedan Zeleni kabal (od kamere) i nije isti model racunara koji si postavio u prvom postu ove teme!
Jedino da imaju dodatni swich tamo negde kod kamera na krovu, plavi kablovi su digitalne I/O koje pale/gase tamo neke senzore/LED sta vec ... @1van hoces block shemu da ti nacrtam? : )
I da, imaju WiFi ali za interni tablet koji prikazuje tu sta se desava ... OpenCV kuva samo tako : )
[Image: attachment.php?aid=33882]
Hvala Miki Smile Nemam blage veze sta je ova velika crna kutija... možda hard diskovi Big Grin
Hard diskovi sa mehanickim ziroskopskim stabilizatorima i dole na vazdusnim jastucima oklopljeno olovom zbog moguceg atomskog s'guza Big Grin (zezam se naravno da me neko ne shvati za ozbiljno)
Jel se zna uopste ko je njima ovo sklapao i budzio i cemu uopste sluzi onoliki akumulator (u autu sa alternatorom od preko 1kw), koja je sustina ?
Nekad sam vozio vozilo slicne konstrukcije-drugacije namjene. Komunikacijski akumulator se napaja sa
posebnog alternatora, da vozilo zbog potrosnje komunikacijskog dijela ne ostane sa praznim akumulatorom.-
Sve je to ok bilo nekada, to vozilo ne znam sta je nosilo od opreme ali cenim da je i trosilo puno, ali danas sa modernim cpu/gpu nema sanse da nagura za ono sto treba vise od 200w potrosnje tako da ne shvatam cemu onoliki aku, sem ako neko pametan nije smislio da se sve ono napaja iz aku nezavisno od auta i da se po povratku u bazu akumulator stavlja na punjac . Iskreno me ne bi zacudilo i da je tako Smile
Umjesto one misteriozne crne kutije u prtljazniku je stajao agregat 2,5kW i servostabilizator napona, a potrosnja je bila
"mašala"- KT primopredajnik 100W+ nekoliko nezavisnih prijemnika+tri UKW stanice.
Agregat se koristio kada se nadjes stacioniran negdje u "nedodjiji"-gdje nema struje. KT se koristio stacionarno a UKW
i u pokretu.
Sto se tice ovog "Oka sokolova", ono racunarce je sa pasivnim hladjenjem /odatle onaj hladnjak s gornje strane/ i suma
sumarum dobro si procijenio potrosnju . Crna kutija sa zutim katancem izgleda da samo opravdava velicinu "a ne i
marku vozila. @Branko tod postavi sliku skutera iste namjene. Podaci se salju i obradjuju negdje drugo.-
Blok šema sistema:
[Image: Mito.JPG]
________________________________________
emiSAr pozdrav
Crna kutija je frižider za sendviče i sok... žuti..."grobljanac".
Glupo bi bilo da se vidi pa ga spakovali ovako.
