1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
RE: APEX AX11 : Simple 100W/4R Amp - HomeMadeAudioProject - 12-22-2019 poodavno sam imao želju da ojačam AX11 do maksimuma a bez H-step dela,i krenuo baš od njega: RE: APEX AX11 : Simple 100W/4R Amp - apexaudio - 12-23-2019 (12-22-2019, 10:33 PM)HomeMadeAudioProject Wrote: poodavno sam imao želju da ojačam AX11 do maksimuma a bez H-step dela,i krenuo baš od njega: Postoji najjaca verzija AX11 bez H-stepa, a to je BX22. Postoji i plocica, a bilo je i uspesnih gradnji. RE: APEX AX11 : Simple 100W/4R Amp - HomeMadeAudioProject - 12-23-2019 ha haa - ovaj će ostati u AB-klasi... još nije isproveravano,i treba da postavim nazive i redne brojeve delova kako bi sprint mogao izbaciti kompletan spisak delova. RE: APEX AX11 : Simple 100W/4R Amp - HomeMadeAudioProject - 12-23-2019 C1 4u7 1 --- --- --- R--- Top C2 4u7 2 --- --- --- R--- Top C3 220p 3 --- --- --- R--- Top C4 100u63V 4 --- --- --- R--- Top C5 47u63V 5 --- --- --- R--- Top C6 100n 6 --- --- --- R--- Top C7 220p 7 --- --- --- R--- Top C8 220p 8 --- --- --- R--- Top C9 100n 9 --- --- --- R--- Top C10 100u63V 10 --- --- --- R--- Top C11 100n 11 --- --- --- R--- Top C12 100u63V 12 --- --- --- R--- Top C13 100n 13 --- --- --- R--- Top C14 100u63v 14 --- --- --- R--- Top C15 100n 15 --- --- --- R--- Top C16 220u63v 16 --- --- --- R--- Top C17 100u63v 17 --- --- --- R--- Top C18 100n 18 --- --- --- R--- Top C19 100n 19 --- --- --- R--- Top C20 100u63v 20 --- --- --- R--- Top C21 100n 21 --- --- --- R--- Top C22 100u63v 22 --- --- --- R--- Top C23 220u63V 23 --- --- --- R--- Top C24 47u63v 24 --- --- --- R--- Top C25 47u63v 25 --- --- --- R--- Top C26 100n100v 26 --- --- --- R--- Top CON GND 27 --- --- --- R--- Top CON OUT 28 --- --- --- R--- Top CON+ 29 --- --- --- R--- Top CON- 30 --- --- --- R--- Top D1 4148 31 --- --- --- R--- Top D2 4148 32 --- --- --- R--- Top D3 4148 33 --- --- --- R--- Top F1 10A 34 --- --- --- R--- Top F2 10A 35 --- --- --- R--- Top R1 10r 36 --- --- --- R--- Top R2 22k 37 --- --- --- R--- Top R3 2k2 38 --- --- --- R--- Top R4 22k 39 --- --- --- R--- Top R5 680r 40 --- --- --- R--- Top R6 2k2 41 --- --- --- R--- Top R7 22k 42 --- --- --- R--- Top R8 680r 43 --- --- --- R--- Top R9 680r 44 --- --- --- R--- Top R10 10r 45 --- --- --- R--- Top R11 10r 46 --- --- --- R--- Top R12 180r 47 --- --- --- R--- Top R13 680r 48 --- --- --- R--- Top R14 4K7 49 --- --- --- R--- Top R15 3k3 50 --- --- --- R--- Top R16 47r 51 --- --- --- R--- Top R17 47r 52 --- --- --- R--- Top R18 220r 53 --- --- --- R--- Top R19 0r67 2W 54 --- --- --- R--- Top R20 0R67 2W 55 --- --- --- R--- Top R21 0R67 2W 56 --- --- --- R--- Top R22 0R67 2W 57 --- --- --- R--- Top R23 0R67 2W 58 --- --- --- R--- Top R24 0R67 2W 59 --- --- --- R--- Top R25 0R67 2W 60 --- --- --- R--- Top R26 0R67 2W 61 --- --- --- R--- Top R27 0R67 2W 62 --- --- --- R--- Top R27 0R67 2W 63 --- --- --- R--- Top R28 0R67 2W 64 --- --- --- R--- Top R29 0R67 2W 65 --- --- --- R--- Top R30 0R67 2W 66 --- --- --- R--- Top R31 0R67 2W 67 --- --- --- R--- Top R32 0R67 2W 68 --- --- --- R--- Top R33 0R67 2W 69 --- --- --- R--- Top R34 0R67 2W 70 --- --- --- R--- Top R35 0R67 2W 71 --- --- --- R--- Top R36 4r7 2W 72 --- --- --- R--- Top R37 10r 73 --- --- --- R--- Top R38 10r 74 --- --- --- R--- Top R39 10r 75 --- --- --- R--- Top R40 10r 76 --- --- --- R--- Top R41 10r 77 --- --- --- R--- Top R42 10r 78 --- --- --- R--- Top T1 BC546B 79 --- --- --- R--- Top T2 BC546B 80 --- --- --- R--- Top T3 BC546B 81 --- --- --- R--- Top T4 MPSA92 82 --- --- --- R--- Top T5 MPSA92 83 --- --- --- R--- Top T6 MJE340 84 --- --- --- R--- Top T7 MJE350 85 --- --- --- R--- Top T8 BC679 86 --- --- --- R--- Top T9 MJE15034 87 --- --- --- R--- Top T10 MJE15035 88 --- --- --- R--- Top T11 2SC5200 89 --- --- --- R--- Top T12 2SC5200 90 --- --- --- R--- Top T13 2SC5200 91 --- --- --- R--- Top T14 2SA1943 92 --- --- --- R--- Top T15 2SA1943 93 --- --- --- R--- Top T16 2SA1943 94 --- --- --- R--- Top ako to sad nije to - onda ću i sam imati problem oko njega. koliko sam gledao i video-to je to. RE: APEX AX11 : Simple 100W/4R Amp - Dackotronic - 12-23-2019 Odlicno odradjena plocica , svaka cast ![]() ![]() RE: APEX AX11 : Simple 100W/4R Amp - HomeMadeAudioProject - 12-23-2019 hvala Dacko hvala! ma ja to i po sebi... ? a ima i ona ruska:"Bolje tri tone previše nego tri grama premalo..." ja idem po prvoj opciji ???? RE: APEX AX11 : Simple 100W/4R Amp - Dackotronic - 12-24-2019 (12-16-2019, 03:02 PM)apexaudio Wrote: APEX CA8 Vecerasnja zanimacija , pcb za CA8 ![]() ![]() ![]() RE: APEX AX11 : Simple 100W/4R Amp - apexaudio - 12-24-2019 Trimer je pogresno povezan... RE: APEX AX11 : Simple 100W/4R Amp - Dackotronic - 12-24-2019 (12-24-2019, 09:51 AM)apexaudio Wrote: Trimer je pogresno povezan... Hvala Mile , greska ispravljena . Neverovatno mi kako ja to nevidim odmah ![]() ![]() RE: APEX AX11 : Simple 100W/4R Amp - apexaudio - 12-24-2019 (12-24-2019, 11:51 AM)Dackotronic Wrote:(12-24-2019, 09:51 AM)apexaudio Wrote: Trimer je pogresno povezan... Hvala za ovu plocicu, verujem da ce biti nekih gradnji u buducnosti. Sve cesce na slusnim testovima pobedjuju pojacala bazirana na koriscenju OP ampova bez obzira da li su u pitanju CFA, VFA ili kombinovane topologije kao kod A9. RE: APEX AX11 : Simple 100W/4R Amp - HomeMadeAudioProject - 01-04-2020 ako nema grešaka kontam da je ovo konačna verzija moje pločice. dodao sam APEX kontrole(Power Signal Clip) i izmenio nešto oko kondenzatora iza osigurača: C1 4u7 1 --- --- --- Top C2 4u7 2 --- --- --- Top C3 220p 3 --- --- --- Top C4 100u63V 4 --- --- --- Top C5 47u63V 5 --- --- --- Top C6 100n 6 --- --- --- Top C7 220p 7 --- --- --- Top C8 220p 8 --- --- --- Top C9 100n 9 --- --- --- Top C10 100u63V 10 --- --- --- Top C11 100n 11 --- --- --- Top C12 100u63V 12 --- --- --- Top C13 100n 13 --- --- --- Top C14 100u63v 14 --- --- --- Top C15 100n 15 --- --- --- Top C17 100u63v 16 --- --- --- Top C18 100n 17 --- --- --- Top C19 100n 18 --- --- --- Top C20 100u63v 19 --- --- --- Top C21 100n 20 --- --- --- Top C22 100u63v 21 --- --- --- Top C23 470uF63V 22 --- --- --- Top C24 47u63v 23 --- --- --- Top C25 47u63v 24 --- --- --- Top C26 100n100v 25 --- --- --- Top C27 470uF63V 26 --- --- --- Top C28 220uF63C 27 --- --- --- Top C29 220uF63C 28 --- --- --- Top C30 220n 29 --- --- --- Top C31 470n 30 --- --- --- Top C32 470n 31 --- --- --- Top C33 220n 32 --- --- --- Top C1.A smd 33 --- --- --- Top C1.B smd 34 --- --- --- Top C2.A smd 35 --- --- --- Top C2.B smd 36 --- --- --- Top Clip RED 37 --- --- --- Top CON OUT 38 --- --- --- Top CON+ 39 --- --- --- Top CON+ 40 --- --- --- Top CON+ 41 --- --- --- Top CON+ 42 --- --- --- Top D1 4148 43 --- --- --- Top D2 4148 44 --- --- --- Top D3 4148 45 --- --- --- Top D1A 4007 46 --- --- --- Top D2A 4148 47 --- --- --- Top F1 10A 48 --- --- --- Top F2 10A 49 --- --- --- Top Power GREEN 50 --- --- --- Top R1 10r 51 --- --- --- Top R2 22k 52 --- --- --- Top R3 2k2 53 --- --- --- Top R4 22k 54 --- --- --- Top R5 680r 55 --- --- --- Top R6 2k2 56 --- --- --- Top R7 22k 57 --- --- --- Top R8 680r 58 --- --- --- Top R9 680r 59 --- --- --- Top R10 10r 60 --- --- --- Top R11 10r 61 --- --- --- Top R12 180r 62 --- --- --- Top R13 680r 63 --- --- --- Top R14 4K7 64 --- --- --- Top R15 3k3 65 --- --- --- Top R16 47r 66 --- --- --- Top R17 47r 67 --- --- --- Top R18 220r 68 --- --- --- Top R19 0r67 2W 69 --- --- --- Top R20 0R67 2W 70 --- --- --- Top R21 0R67 2W 71 --- --- --- Top R22 0R67 2W 72 --- --- --- Top R23 0R67 2W 73 --- --- --- Top R24 0R67 2W 74 --- --- --- Top R25 0R67 2W 75 --- --- --- Top R26 0R67 2W 76 --- --- --- Top R27 0R67 2W 77 --- --- --- Top R27 0R67 2W 78 --- --- --- Top R28 0R67 2W 79 --- --- --- Top R29 0R67 2W 80 --- --- --- Top R30 0R67 2W 81 --- --- --- Top R31 0R67 2W 82 --- --- --- Top R32 0R67 2W 83 --- --- --- Top R33 0R67 2W 84 --- --- --- Top R34 0R67 2W 85 --- --- --- Top R35 0R67 2W 86 --- --- --- Top R36 4r7 2W 87 --- --- --- Top R37 10r 88 --- --- --- Top R38 10r 89 --- --- --- Top R39 10r 90 --- --- --- Top R40 10r 91 --- --- --- Top R41 10r 92 --- --- --- Top R42 10r 93 --- --- --- Top R1A 6k8/2W 94 --- --- --- Top R2A 10k 95 --- --- --- Top R3A 47k 96 --- --- --- Top Signal YELLOW 97 --- --- --- Top T1 BC546B 98 --- --- --- Top T2 BC546B 99 --- --- --- Top T3 BC546B 100 --- --- --- Top T4 MPSA92 101 --- --- --- Top T5 MPSA92 102 --- --- --- Top T6 MJE340 103 --- --- --- Top T7 MJE350 104 --- --- --- Top T8 BC679 105 --- --- --- Top T9 MJE15034 106 --- --- --- Top T10 MJE15035 107 --- --- --- Top T11 2SC5200 108 --- --- --- Top T12 2SC5200 109 --- --- --- Top T13 2SC5200 110 --- --- --- Top T14 2SA1943 111 --- --- --- Top T15 2SA1943 112 --- --- --- Top T16 2SA1943 113 --- --- --- Top T1a 2N5551 114 --- --- --- Top T2a 2N5551 115 --- --- --- Top ZY1A ZY15 116 --- --- --- Top RE: APEX AX11 : Simple 100W/4R Amp - ivanlukic - 01-04-2020 Bilo je na forumu više projekata sa LME driverskim IC, a i to je neka vrsta OP. Jedino što nisam video, a što bi bilo i daleko jeftinije od LME, je TDA7250. To je stereo driver IC tako da je i vrlo praktičan. Nema štelovanja bilo koje vrste a jedino ograničenje je da ne može da se napravi pojačalo jače od 60W ali ja i ne pravim jaka pojačala (za razglase). Možda negde kod nas mogu da se kupe TDA7250 driverski IC? Možda topologije sa OP na ulazu daju tako dobre subjektivne rezultate zato što je ceo ulazni stepen pojačala u tom slučaju spakovan na jako mali prostor? RE: APEX AX11 : Simple 100W/4R Amp - apexaudio - 01-04-2020 Postoji tema o pojacalima koja koriste OP amp sa plivajucim napajanjem u odnosu na izlazni napon. https://forum.yu3ma.net/thread-1011-page-7.html Na ovaj nacin izbegnut je kompletan VAS stepen, pojacalo moze da koristi bilo koji napon napajanja koji podrzavaju izlazni tranzistori, a obezbedjena je rail to rail pobuda. Koriste se standardni OP ampovi a ne specijalni drajverski koji su prevazidjeni i predstavljaju veliki korak nazad u svim karakteristikama. RE: APEX AX11 : Simple 100W/4R Amp - ghostrider - 01-04-2020 (01-04-2020, 07:46 PM)apexaudio Wrote: Postoji tema o pojacalima koja koriste OP amp sa plivajucim napajanjem u odnosu na izlazni napon. Mile da li ovde moze da se koristi bilo koji bipolarni op amp novije generacije RE: APEX AX11 : Simple 100W/4R Amp - apexaudio - 01-04-2020 Iako deluje previse lepo da bi bilo istinito, topologija je proverena. Mislio sam da ce u buducnosti ova topologija biti najzastupljenija pored D klase. Prednosti su veliki raspon snaga od 30W do 3000W ako nekome treba i nema visokonaponskih VAS tranzistora koji rade sa velikom disipacijom. Izbor VAS tranzistora je veliki problem kod svih topologija , a ovde ih uopste nema, potreban je jedan kvalitetan OP amp i dva izlazna tranzistora za high-end pojacalo preko 100W snage. Nikako mi nije jasno zasto se ova superiorna topologija ignorise!? RE: APEX AX11 : Simple 100W/4R Amp - apexaudio - 01-04-2020 (01-04-2020, 07:58 PM)ghostrider Wrote:(01-04-2020, 07:46 PM)apexaudio Wrote: Postoji tema o pojacalima koja koriste OP amp sa plivajucim napajanjem u odnosu na izlazni napon. Moze, ali da ne bude CFA sto nije problem jer je vecina OP ampova VFA. Ja sam pored ovog MC koristio i standardni NE5532. Bez obzira na modu da se koriste diskretni OP ampovi oni su inferiorni u odnosu na integrisane cak i kad se koriste dupli fetovi na ulazu i smd komponente. RE: APEX AX11 : Simple 100W/4R Amp - Bocko - 01-04-2020 &HMAP: Komšo, gledam malko ovaj tvoj AX11 XXXL i na slikici mi nešto nije jasno, 250W8Ohm i 150W8Ohm? Pozzz RE: APEX AX11 : Simple 100W/4R Amp - HomeMadeAudioProject - 01-04-2020 e jbg...greška u štampariji... prepraviću to,hvala Bocko! nadam se da je to jedina greška-sa tim bi se dalo živeti ? RE: APEX AX11 : Simple 100W/4R Amp - HomeMadeAudioProject - 01-05-2020 (01-04-2020, 09:05 PM)Bocko Wrote: &HMAP: ispravljeno (valjda...) RE: APEX AX11 : Simple 100W/4R Amp - samuki - 01-05-2020 150w je sa cetiri para izlaznih a 280w je sa sest pari izlaznih ! Jel tako? |
