DIY Electronic projects
RE: Class D Amplifier - High Quality Power Audio Amplifier - Dragan100 - 07-02-2022
(07-02-2022, 05:10 PM)savan Wrote:
(07-02-2022, 04:31 PM)Dragan100 Wrote:
(07-02-2022, 03:37 PM)savan Wrote: Shem na kojoj se zastalo
Nadam se na poručene dobre LMG3411R050, pa čemo sa njima, bit če možda samo nekoliko minornih izmjena u shemi...
Šta nam još treba? da se nabavi, dok ima!!!   :-)
FlyBUCK trafojčeti VPH2-0116-R
https://www.digikey.si/en/products/detail/eaton-electronics-division/VPH2-0116-R/668191?s=N4IgTCBcDaIG4AcAWYC0AGAjJgbKgTiALoC%2BQA
https://www.eaton.com/content/dam/eaton/products/electronic-components/resources/data-sheet/eaton-vp-versa-pac-inductors-transformers-data-sheet.pdf
I izlazni kalem-i 10...15uH setio sam se da nam treba/ju https://www.mouser.it/datasheet/2/597/ver2923-270656.pdf
https://www.mouser.it/ProductDetail/Coilcraft/VER2923-103KL?qs=zCSbvcPd3pYFGNEVSZE3iw%3D%3D
???? šta još ???
LT3045 i LT3094 da se uzme, zatrebat če, ...koju pakungu?
https://www.digikey.si/en/products/detail/analog-devices-inc/LT3094EDD-PBF/9607277?s=N4IgjCBcoLQExVAYygFwE4FcCmAaEA9lANogCsIAugL7X4KSkA2qAzAAwCcALFdUA
Po ovoj shemi gore ja sam narucio skoro sve, fali mi izlazni kalem, pa onda trafojce za flybuck, i ovi LT buck konverteri, pre sat vremena sam narucio sa digikey INA i 4 komada LT3094 i 10 komada LT3045, sad je samo pitanje ako mi odgode opet INA onda moram da odustanem i od ova dva. Kuci vec imam  dva komada LMG3410R050, ako bi sa njima isli umesto sa tim novijim  LMG3411R050, onda nam fali svih 4 komada  LMG3411R050. Ako bi isli sa ovima sa sheme kojih imam dva komada  LMG3410R050, onda nam fale samo dva komada. Ti kazes da si narucio  LMG3410R050 ?
Naručio sam LMG3411R050 4kom, prvo da vidim dali so OK, ....a imaju jih još nekoliko komada
Digikey ima i trafojče
https://www.digikey.pl/pl/products/detail/eaton-electronics-division/VPH2-0116-R/668191?s=N4IgTCBcDaIG4AcAWYC0AGAjJgbKgTiALoC%2BQA
RE: Class D Amplifier - High Quality Power Audio Amplifier - savan - 07-02-2022
Na Digikey ima 6 komada LMG3410R050 dok ovih LMG3411R050 ima 288 komada, sad koja je razlika ne znam, ovi prvi nemaju OCP? Do jedanajstog u ovom mesecu imam fore da dodam jos po koji deo dok jos nisu poslali paket, stvarno ne mogu vise vec sam ispunio bonus za ovaj mesec, registracija auta, more, danas narucio LT3045, LT3094, INA849. Lead time INE je 11.07.2022, do tada bi mozda mogao dodati jos dva komada LMG3410R050 ako nam oni odgovaraju, ili mozda umesto njih po koji trafojce za flybuck. Ja cu i da nacrtam plocicu i da je narucim i da zalemim sve delove koji su mi na raspolaganju i prosledim dalje, mozda da ti zalemis tih 4 komada LMG? Sta cemo za izlazni kalem? Braco koji ti imas? Ostale delove imam, i MAX flybuck driver, komparator, iso drajvere, kapije... itd
RE: Class D Amplifier - High Quality Power Audio Amplifier - mikikg - 07-02-2022
Niste zaboravili na VCA/PGA? Smile
Treba prepraviti onu shemu gore i dodati sta treba a sta ne treba, pa po tome da vidimo sta nam sve fali. Do 11.07. bi to trebali odraditi jer ne smem da propustim INA849, cekam je 3-4 meseca nikako da dodjem do nje, tako da bi korpu za to vreme mogao da prepravim. Samo sa Digikey narucujem jer su ok sto se tice free shipinga kada vrednost robe predje 150$ dok je na Mouser slanje preskupo pa od njih ne kupujem nista jer onda ovi nasi lopovi uracunaju pdv i na vrednost slanja sto onda sve skupa izadje koliko je i sama roba. Na LCSC je to drugacije vec imam taktiku kako da izbegnem pdv, kazem im da ne stavljaju cenu na fakturi nego samo da napisu koliko komada bez cene, onda ovi nemaju vremena da gledaju koliko sta kosta Smile
RE: Class D Amplifier - High Quality Power Audio Amplifier - gorso69 - 07-02-2022
Koja INA849 tebi treba?Sad spominješ SOIC8 a na PCB su ti VSSOP.Ja imam SOIC 8 spremne za Dragan100 projekat pa ako ti znači nešto pozajmica javi se.
Ne preostaje mi nista drugo nego novi pcb da pravim jer vssop8 tesko da ce pre kraja godine biti na stanju, sumnjam i da ce soic8 da bude dostupan za 11.07, ako ne posalju 11-stog javim ti! Prodao bi mi dva komada?
Nije za prodaju.Može pozajmica.Imam komplet IC za BatoMDM FronEND i nebih
da ga rasparujem na večito.
Ok onda bolje onda da ne pozajmljujem jer nije bas preporucljivo da se jedan takav ultra precizan ic razlemljava i greje vise puta, hvala u svakom slucaju!
Nisam mislio da ga razlemljavaš nego kad kupiš za mesec,dva,pet onda vratiš.
RE: Class D Amplifier - High Quality Power Audio Amplifier - Dragan100 - 07-03-2022
(07-02-2022, 06:55 PM)mikikg Wrote: Niste zaboravili na VCA/PGA? Smile
VCA810
https://www.ti.com/lit/ds/symlink/vca810.pdf?ts=1656802236288&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FVCA810
sa 0-->2V Vprog odradimo od -40dB -->+40dB pojačanja, prilagodimo sa ulaznim dividerom šta nam tačno treba
Če odgovarati?
Napon PSU +HV Volume direktno kontrolira VCA, a ovaj radi diff-to SE conversion i prosleduje do P2 n_pin I/O ADCja
Takodjer P2 na nekom n_pin I/O čita napon PSU Volume, i na vrlo malim razinama napona PSU Volume,
tada kad nam bude izlaz VCA-->ADC konvertiran zapravo "neupotrebljiv" = vrlo male resolucije
e tada ne koristi FB, i ide se sa sasvim Open-Loop
(07-02-2022, 06:33 PM)savan Wrote: Na Digikey ima 6 komada LMG3410R050 dok ovih LMG3411R050 ima 288 komada, sad koja je razlika ne znam, ovi prvi nemaju OCP?
"LMG3410R050 provides latched OCP option, by which the FET is shut off and held off until the fault is reset by either holding the IN pin low for more than 350 μs or removing power from VDD. "
Tu treba onda ta RC timing konstanta na nERR, da postavi inpute na LOW za tih >350usec
kao "Draganče, ...isključuj muziku!!!"
"LMG3411R050 provides cycle-by-cycle OCP option. In this mode, the FET is also shut off when overcurrent happens, but the output fault signal will clear after the input PWM goes low. In the next cycle, the FET can turn on as normal. The cycle-by-cycle function can be used in cases where steady state operation current is below the OCP level but transient response can still reach high current, while the circuit operation cannot be paused. It also prevents the power stage from overheating by having overcurrent induced conduction loss."
Tu se samo resetira poslije sledečeg input stanja LOW,  ili postavljanjem nERR bez ili krače RC konstante,
ali treba paziti da nije to dugotrajno i duže repetitivno, jer tu smo onda više vremena u III.kvadrantu (LO side driver) gdje imamo veču disipaciju/gubitke,
OK, tu nam je onda u pomoč i OTP (OverTemperatureProtekt)
RE: Class D Amplifier - High Quality Power Audio Amplifier - mikikg - 07-03-2022
VCA810
Če odgovarati?
Aahaa, ako taj treba onda taj imamo na lageru!
Čika Teksas donirao pre tačno 10 godina, gledam pakovanje ...
VCA810AID 8-SOIC, komada 3!
Valjalo bi da se nacrta PCB za Stereo varijantu, sad imamo delova za jedan kanal, kada stignu ostali delovi kompletiramo drugi kanal, nije praktično da to razdvajamo u mono blokove.
Našao sam i ADC, mislim da će biti "dovoljno dobar" za naše potrebe.
PCM1804DB 28-SSOP, komada 3!
https://www.ti.com/lit/ds/symlink/pcm1804.pdf
Jedan je dovoljan za Stereo varaijantu.
RE: Class D Amplifier - High Quality Power Audio Amplifier - savan - 07-03-2022
Hvala gorso69, javim ti za desetak dana!
Moze i diskretni i2s prihvat za konverziju u levi i desni PDM da se odradi https://forum.yu3ma.net/attachment.php?aid=37713 tih par kapija bez ove polovine gde su 8bit shift i otpornici, odatle bi islo na komplementarna razdvajanja za levi i desni kanal. Tu imamo i mute koji bi isao direktno na nErr. Na ovaj bi nacin most mogao da se proba bez kontrolera i bez fb i imali bi i2s ulaz, to bi ustvari bila minimalna plocica na koju posle moze da se dodaje sta treba. I2s nebi radio sa PCM nego mora da bude DSD format
VCA810
Če odgovarati?
(07-03-2022, 02:15 AM)mikikg Wrote: Našao sam i ADC, mislim da će biti "dovoljno dobar" za naše potrebe.
Da, ovaj ADC je podosta precizniji od ADCja kojih ima interno P2. :-)
[Image: attachment.php?aid=37901]
VCA810 sam simulirao u nekom okruženju FullBridgeDclasse,
kojoj se podešava PSU napon izlaznog stepena u rasponu 0...50VDC kao VOLUME.
-izlaz SPK_OUT Dclasse je preko LC filtracije onda neki pseudo-sinus 10KHz,
visinom amplitude u zavisnosti od podešenog napona PSUja.
Ujednom ostaje dinamika sve vreme visine napona PSUja ista, pošto ne menjamo drive mosfeta FullBridga,
znači PSU_reg = VOLUME (sa full dinamic range PDM ulaza u Dclassu,
to jest tu je ulazni signal u Dclassu, taj VOLUME Out DSD ili PDM uvijek na 100%, punom/max resolucijom)
-VCA810 drivuje se Vcontrol preko OPAMP invertera -1 GAINa, kontroliramo ga iz nekog I/O n_pina P2,
koji prati (opet na nekom n_pinu P2) napon PSUja izlaza Dclasse.
Odradio sam na brzinu neku zavisnost tog PSU napona -->Vcontrol preko VoltageControledVoltageSource (što če nam raditi P2)
samo u nekim marginalnim tačkama (nisam se potrudio na preciznosti) 50/40/30/20/10/5/2,5/1/0,5V PSU
i zapisao u tabelu tog VCVSa
U grafu vidi se, da napon na Vout prati sa +/-500mVpeak amplitudu na SPK_OUT u zavisnosti PSU napona.
(vidi se i ta moja ne-preciznost  :-)   ...izlazna amplituda šeta gore/dole za par mVpeak)
-min PSU napon bio bi 500mVDC, tada je izlazni napon VCAja još +/-500mV, tada i sa punim GAIN VCAja (-2V Vcontrol)
radi i sa manjim naponom PSU, ali tada treba reči P2, da radi Open-Loop,
jer nam je amplituda Vout sada manja, i time ADC konverzija manjom dinamikom = večim pogreškom,
pa da je ne unosimo preko NFBja nazad!!!
-max PSU napon bio bi 50VDC (ili viši, pa se dotera tabelu kasnije u P2)  = sa PSU 50VDC je cca 150Wrms/8R0 FullBridge
-OPAMP nije tu kritičan, pa se stavlja neki koji lepo radi i sa +/-5VDC napajanjem
-ulazni divider VCAja neka je takav da sa max PSUjem nemamo višu amplitudu na ulazu u VCA od +/-500mVpeak,
tako smo podalje od naponskog klippinga VCAja, pa se ga višim naponom maxPSUja adekvatno podesi!
.tsc   VCA810.TSC (Size: 101,23 KB / Downloads: 1)
Dobro je ovo samo ja mislim da zaboravljate na to da imamo izolovanu digitaliju od analogije, zato nam isto treba i adc za fb da bude izolovan. Kako dodati posle osetljive ic-ove recimo FM radio ako ne izolujemo H most od digitalije? A imamo ga vec izolovanim. Pokusavam da nadjem dali ima vec neki gotov produkt koji ima izolaciju i ujedno i ovaj vca ili pga a da prihvata na ulaz recimo 100V a da ima i integrisan adc. Mozda ovako nesto https://eu.mouser.com/datasheet/2/256/MAX22530-2199797.pdf ili na ovo Draganovo dodati ovako nesto ISOSD61 , ADuM7701 ?
RE: Class D Amplifier - High Quality Power Audio Amplifier - yugaja - 07-03-2022
Ako je ulaz u kutiju isključivo digitalan, izolacija može da se vrši na samom ulazu (pdm, i2s spdif whatever..) i da ceo pojačavač: modulator i izlazni stepen i sva salata okolo, šeruju izolovani gnd.
Pustimo taj VCA810, PCM1804 odradi ADC a ISO_digital (ISO7840F) poslije stavimo koliko kanala nam treba za NFB
RE: Class D Amplifier - High Quality Power Audio Amplifier - savan - 07-04-2022
Ok moze i tako, kazem samo da mozda vec ima jedan takav ic koji u sebi vec ima sve ovo
