Oscillation Sniffer by Bonsai - Printable Version +- DIY Electronic projects (https://forum.yu3ma.net) +-- Forum: Merenja i merni uređaji - Measurements and Equipment (https://forum.yu3ma.net/forumdisplay.php?fid=8) +--- Forum: Merenja i merni uređaji - Measurements and Equipment (https://forum.yu3ma.net/forumdisplay.php?fid=32) +--- Thread: Oscillation Sniffer by Bonsai (/showthread.php?tid=1031) |
Oscillation Sniffer by Bonsai - ivanlukic - 08-05-2015 Jako korisno za one koji hoće da detektuju nestabilnost a nemaju osciloskop. Da li neko zna gde mogu da se nabave diode pomenute u textu koje omogućavaju bolju detekciju od 1N4148. RE: Oscillation Sniffer by Bonsai - ivanlukic - 08-05-2015 Evo šta je odlično a možda može lakše da se nađe: There are several, commonly available, Schottky diodes intended for UHF detector applications. They should equal the venerable 1N34 (or 1N21) for sensitivity, even when you aren't looking for signals at 1 GHz and above. Designations include the BAT68, HSMS2850 and HSMS2860, and MBD101. RE: Oscillation Sniffer by Bonsai - ivanlukic - 08-05-2015 Znači, najbolje je da bude mala signalna germanijumska dioda ili šotki dioda za "mixer applications in UHF/VHF range". Ništa od toga ne uspevam da nađem u našim dućanima. RE: Oscillation Sniffer by Bonsai - emiSAr - 08-05-2015 Potrazi nesto kao BAT46 ili BAT42 ili BAT43 Obrati paznju na prag otvaranja pri malim strujama.- A ni 1N4148 nije za baciti. Drugi pdf crtez-png je za BAT46.- pOz RE: Oscillation Sniffer by Bonsai - ivanlukic - 08-05-2015 Hvala emiSAr. U lokalnom dućanu ima i BAT43 i BAT46. |
