APEX NE555 zaštita
07-21-2013, 09:12 PM
(This post was last modified: 04-20-2014, 04:25 PM by HomeMadeAudioProject.)
Pitam se da li je za ovo moguće koristiti one HG.... (ne sećam se tačne oznake) reed releje koje imamo ja i ti?
07-21-2013, 10:19 PM
(This post was last modified: 04-20-2014, 04:26 PM by HomeMadeAudioProject.)
(07-21-2013, 08:18 PM)HomeMadeAudioProject Wrote: <p>uz ovu cijenu</p> <p>Struja potrebna za napajanje releja je 77mA, a NE555 moze da isporuci 200mA.</p>
APEXaudio.MileSlakovic
mozda grijeshim ali ic 4i 8 nozica sto ide na +12v , nije spojena ! na plocici
07-21-2013, 11:23 PM
<blockquote class="ipsBlockquote" data-author="HomeMadeAudioProject" data-cid="7419" data-time="1374434282"><p><a href="http://forum.diyaudioproject.eu/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=3155">BS901AS prednjica.JPG</a> <a href="http://forum.diyaudioproject.eu/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=3156">BS901AS zadnjica.JPG</a><br><br>
uz ovu cijenu<br><br><a href="http://store.comet.rs/Catalogue/Product/29043/">http://store.comet.rs/Catalogue/Product/29043/</a> <br><br> teško da može bolje,još samo ako struja kalema releja nije "preteška" za NE555...</p></blockquote> ova plocica nije spojeno ic na 12v
07-22-2013, 04:31 AM
u pravu si - popraviću to - dobro si primjetio,hvala!
07-22-2013, 06:35 AM
<blockquote class="ipsBlockquote" data-author="TDA" data-cid="7420" data-time="1374437539"><p>
Pitam se da li je za ovo moguće koristiti one HG.... (ne sećam se tačne oznake) reed releje koje imamo ja i ti?</p></blockquote>ako hoces jace releje da stavis , ubaci jedan tranzistor na izlaz 3 nozica
07-22-2013, 07:45 AM
Reed releji nisu jači. nego nisu namenjeni za ovakvu primenu.
07-22-2013, 10:03 AM
<blockquote class="ipsBlockquote" data-author="HomeMadeAudioProject" data-cid="7030" data-time="1373382789">
<div> <p>it is a good thing to have it here too,i personaly would like to have here all possible versions of a pcb. i plan to draw a few more versions with various relay types. today i found T9 relay for just 1,2 euros...</p> </div> </blockquote> <p></p> <p>Sorry....I missed this.....</p> <p>i just read?your message today bro.... no worries let me post the files tonight.</p> <p></p> <p>Personally i really like the performance of this T9 relay and it's very good to have many version of this APEX NE555 protect?for various amp. application due to its?simplicity, very compact design and excellent performance.</p>
07-22-2013, 01:17 PM
all true! i made a mistake at that pcb,did not connect + supply from 1N4007 to a relay,i will fix it tonight. there is lay6 file,everyone is invited!
<p></p><p></p><blockquote class="ipsBlockquote" data-author="HomeMadeAudioProject" data-cid="7443" data-time="1374495479"><br><br>
all true! i made a mistake at that pcb,did not connect + supply from 1N4007 to a relay,i will fix it tonight. there is lay6 file,everyone is invited! </blockquote><br><br> If you dont mind i made a slight changes, i have fixed the error of positive supply of relay also i change the T9 relay as the pin pitch are missalign and reverse contact orientation .<br><br> Let me know if that's ok with you so i can post the files.<br><br> Regards,
07-22-2013, 07:38 PM
(This post was last modified: 04-20-2014, 04:27 PM by HomeMadeAudioProject.)
wow,i haven´t noticed the diference between relay i used and this one-i have checked it now in pdf and you´re right,that is a proper relay layout and you did it just fine - thanks man! please post other files,including lay. file please. great man,thanks for correcting my errors!
07-22-2013, 07:42 PM
i have checked now - i don´t even have T9 layout in my sprint library,could you post it in attachments,or in some kind of ZIP file?
07-22-2013, 09:24 PM
<blockquote class="ipsBlockquote" data-author="HomeMadeAudioProject" data-cid="7453" data-time="1374518576">
<div> <p>i have checked now - i don´t even have T9 layout in my sprint library,could you post it in attachments,or in some kind of ZIP file?</p> </div> </blockquote> <p>I tried but the thread not accepting the file, i send you PM.</p>
07-22-2013, 09:56 PM
<blockquote class="ipsBlockquote" data-author="HomeMadeAudioProject" data-cid="7452" data-time="1374518309">
<div> <p>wow,i haven´t noticed the diference between relay i used and this one-i have checked it now in pdf and you´re right,that is a proper relay layout and you did it just fine - thanks man! please post other files,including lay. file please. great man,thanks for correcting my errors! </p> <p></p> <p></p> <p></p> <p><a href="http://store.comet.bg/download-file.php?id=2868">http://store.comet.bg/download-file.php?id=2868</a></p> </div> </blockquote> <p></p> <p>Sorry bro i tried many time even to compress it?in zip file?but it's not going, Here's the pdf file.</p> <p>Please PM me your email add i mail it to you.?</p> <p>Regards,</p>
07-23-2013, 07:15 PM
everything is all right,i have received your mail with lay-file and T9 macros file,now we all will have it too (all files needed for APEX NE555 proection with T9 relay) [attachment=4823:T9.zip] i hvala samuki što je primjetio omašku koju sam napravio! and thanks to samuki for notecing mistake that i made!
07-24-2013, 05:00 PM
(This post was last modified: 07-24-2013, 05:02 PM by HomeMadeAudioProject.)
. ako se dobro sjecam podataka sa neta o tim relejima,oni su predvidjeni za neke nize struje,vise su signalni nego snazni a usput su jos i metalni oklopljeni.
07-24-2013, 05:37 PM
Dušu dali za neki preamp...
07-24-2013, 05:51 PM
tako je da,u tu svrhu ih i čuvam
07-24-2013, 08:25 PM
<blockquote class="ipsBlockquote" data-author="HomeMadeAudioProject" data-cid="7486" data-time="1374603351"><p>
everything is all right,i have received your mail with lay-file and T9 macros file,now we all will have it too <br><br> (all files needed for APEX NE555 proection with T9 relay)<br><br><a href="http://forum.diyaudioproject.eu/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=3178">APEX NE555 protect.zip</a><br><br> i hvala samuki što je primjetio omašku koju sam napravio! <br><br> and thanks to samuki for notecing mistake that i made! </p></blockquote> pravio sam ja i pojacalo od ic 555 tako da ga znam u dušu
08-01-2013, 06:44 PM
(This post was last modified: 04-20-2014, 04:28 PM by HomeMadeAudioProject.)
« Next Oldest | Next Newest »
