Izrazi, Skracenice, Termini u vezi elektronike
#41
<p class="">SPS &nbsp;&nbsp; Shock Protection System</p>
<p class="">&nbsp;</p>
<p class="">SRS&nbsp;&nbsp;&nbsp; Semi-conductor Reuse Standard</p>
<p class="">SNS&nbsp;&nbsp;&nbsp; Shunt Noise Suppressor</p>
<p class="">SPO &nbsp;&nbsp; Short Period Oscillation</p>
<p class="">URS&nbsp;&nbsp;&nbsp; University Radiation Safety (various schools)</p>
<p class="">DSS&nbsp;&nbsp;&nbsp; Dynamic Spectrum Sharing</p>
<p class="">PUPS&nbsp; Point-of-Use Power Supply (Nortel)</p>
<p>&nbsp;</p>
<p>JS&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Joint Stereo</p>
<p>&nbsp;</p>
<p>DS&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Data Sheet</p>
<p>&nbsp;</p>
<p>LDP &nbsp;&nbsp; Local Data Processor</p>
<p>&nbsp;</p>
<p>NDS &nbsp;&nbsp; Neutron Discrimination Sensor</p>
<p>&nbsp;</p>
<p>LSV&nbsp;&nbsp;&nbsp; Low starting voltage</p>
<p>&nbsp;</p>
<p>NS &nbsp;&nbsp;&nbsp;&nbsp; No Synchronization</p>
<p>&nbsp;</p>
<p>SSD &nbsp; Simultaneous Signal Detection</p>
<p>&nbsp;</p>
<p>SDA &nbsp; Stereo Dimensional Array</p>
<p>&nbsp;</p>
<p>Ovih se setih...izvinjavam se zbog zaboravljenih :hmm:</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
&nbsp;
<p>@acivoj, ovo me podseca na neku (pred)izbornu listu.</p>
<p>A ne!</p>
<p>Samo elektronika. Mooožda sam fulao i ubacio malo fizike.</p>
<p>LPF - low pass filter - nisko propusni filter</p>
<p>BPF - band pass fIlter - filter propusnih opsega</p>
<p>CMRR - common-mode rejection ration - faktor potiskivanja nezeljenog signala na ulazu</p>
<p>SOA - safe operating area - "sigurna zona" tranzistora</p>
<p>duty (duty cycle) - koeficijent ispune (faktor rezima), ton/T, moze se izrazavati u procentima ili kao koeficijent</p>
<p>DSP - digital signal processing - digitalna obrada signala</p>
<p>PLL - phase locked loop - fazno zatvorena petlja</p>
<p>DDS - direct digital syntheseizer, frekvencijski sintsisajzer, od referentnog takta pravi proizvoljne talasne oblike</p>
<p>TTL - transistor-transistor logic - vrsta digitalnih kola napravljena od bipolarnih tranzistora</p>
<p>CMOS - complemetary metal-oxide semiconductor - vrsta digitalnih kola napravljena u komplementarnoj MOS tehnici</p>
<p>FFT - fast Fourier transform, <a data-ipb='nomediaparse' href='http://en.wikipedia.org/wiki/Fast_Fourier_transform'>link</a></p>
<p>&nbsp;</p>
<p>Toga sam se setio, nadam se da se ne ponavljam.</p>
<p>Evo jos nekih skracenica kojih sam se dosetio. Izvinjavam se unapred sto su prevodi mozda "drveni", trudim se da ne duzim sa prevodima.</p>
<p>&nbsp;</p>
<p>CODEC - coder/decoder - koder/dekoder</p>
<p>ADSL - asymmertic digital subscriber line - digitalna asimetricna pretplatnicka linija</p>
<p>FIR (filter) - finite impulse response - filter sa konacnim impulsnim odzivom (suprotno od IIR)</p>
<p>LAN - local area network - lokalna mreza</p>
<p>WLAN - wireless local area network - bezicna lokalna mreza</p>
<p>PAM - pulse-amplitude modulation - impulsno amplitudna modulacija</p>
<p>PCM - pulse-code modulation - impulsno kodna modulacija</p>
<p>FPGA - field-programmable gate array - <a data-ipb='nomediaparse' href='http://en.wikipedia.org/wiki/Field-programmable_gate_array'>link</a></p>
<p>SNR - signal-noise ratio - odnos signal-sum</p>
<p>RFID - RF identification - identifikacija putem elektromagnetnih signala</p>
<p>Rx - reciver - prijemnik</p>
<p>Tx - transmitter - predajnik</p>
<p>UPS - uninterruptiple power supply - "neprekidno" napajanje, baterijske rezerve</p>
<p>OVP - over voltage protection - preko naponska zastita</p>
<p>OCP - over current protection - preko strujna zastita</p>
<p>slew rate - brzina opadanja ili porastna napona</p>
<p>Pd - power dissipation - disipacija snage</p>
<p>input bias current - struja baze ulaznih tranzistora u njihovoj radnoj tacki</p>
<p>DC offset - napon razdesenosti na ulazu</p>
<p>input offset voltage drift - napon razdesenosti zbog promene temperature</p>
<p>Nyquist rate - teorema odmeravanja, fo&gt;=2*fmax</p>
