LoRaWAN™ is a Low Power Wide Area Network
Quote:LoRa® is the physical layer or the wireless modulation utilized to create the long range communication link. Many legacy wireless systems use frequency shifting keying (FSK) modulation as the physical layer because it is a very efficient modulation for achieving low power. LoRa® is based on chirp spread spectrum modulation, which maintains the same low power characteristics as FSK modulation but significantly increases the communication range. Chirp spread spectrum has been used in military and space communication for decades due to the long communication distances that can be achieved and robustness to interference, but LoRa® is the first low cost implementation for commercial usage.
Quote:LoRaWAN™ is a Low Power Wide Area Network (LPWAN) specification intended for wireless battery operated Things in a regional, national or global network. LoRaWAN targets key requirements of Internet of Things such as secure bi-directional communication, mobility and localization services. The LoRaWAN specification provides seamless interoperability among smart Things without the need of complex local installations and gives back the freedom to the user, developer, businesses enabling the roll out of Internet of Things.
Quote:https://www.lora-alliance.org/technology
https://docs.wixstatic.com/ugd/eccc1a_ed...c55685.pdf
[Image: attachment.php?aid=25410]
12-01-2017, 10:02 PM
Koji je ovo modul? Čip?
Velika verovatnoća je da je neki od Semtech-a:
http://www.semtech.com/wireless-rf/lora.html
Koliko sam prepoznao to je ovo:
https://wireless-solutions.de/products/r...c880a.html
https://docs.mbed.com/docs/lora-with-mbe...o-to-lora/
LoRaWAN™ ili NarrowBandBand pitanje je sad? Smile
https://en.wikipedia.org/wiki/NarrowBand_IOT
https://www.u-blox.com/en/narrowband-iot-nb-iot
@npejcic ako ste upuceni u detalje, zamolio bi da otvorite novu temu gde bi objasnili prednosti i mane oba resenja (LoRa vs NB-IoT). Hvala Smile
Nisam previše u ovoj temu, ali sam se informisao na kratkom predavanju koje je održao FAE (aplikativni inženjer) iz Quectela, tako da mislim da je dovoljno da ovde napišem par rečenica ukratko kako sam ja razumeo celu priču.
Velika potreba da se IoT useli u svakodnevni život i milijarde uređaja izazvale su da se pored postojećih mogućnosti za konekciju nekog od uređaja na net izrode i novi tipovi konekcija. Najpopularniji među njima su LoRa, NB, Sigfox. Zanimljivo je i preporučujem da se upoznate sa tipom modulacije koja se koristi u ovim konekcijama. Generalno ovi tipovi komunikacije su pokušali da reše probleme kao što su:
1. niska potrošnja (bežični senzori, metrika u industriji i domaćinstvu)
2. značajno veći domet za razliku od sličnih konekcija (BT, WiFi 802.11 itd...)
Moj utisak nakon priče o LoRa-i i NB su da je kod prvih potrebno da postoji mreža posebnih gateway-a koji iako nisu skupi (red veličine 1000-2000 Eura), potrebno je da ih neko instalira kako bi se dobila upotrebljiva mreža. To znači da ukoliko bi recimo moja firma želela da koristi LoRa-u morali bi da investiramo u postavljanje gateway-a ili da evenutalno koristimo neke tuđe koji se nalaze na geografskoj lokaciji gde bi se nalazili end-device uređaji. U Srbiji je još uvek retkost videti LoRa mrežu i u većim gradovima. Gateway ima jedini zadatak da pravi "sponu" između end-device uređaja i servera koji opslužuje tu mrežu.
Sa druge strane NB se oslanja na LTE tehnologiju (spada u njenu podgrupu) koja je uzela prilično maha u različitim oblastima primene i direkno je podržana u 4G mreži koja se velikom brzinom širi od strane mobilnih operatera. Dovoljno je samo instalirati nove firmware u postojeće 4G bazne stanice i dobija se NB funkcionalost. Ovim se olakšava upotreba infrastrukture jer korisnik ne mora da investira u svoju mrežu gatewaya.
Takođe, LoRa ima dosta problema kada se podaci traba da šalju sa servera ka end-device uređaju. Kod NB je to drugačije rešeno i sama bazna stanica se stara o razmeni tih podataka. Korisnik ima mnogo manje problema sa implementacijom iste.
Još par korisnih linkova:
https://www.link-labs.com/blog/lte-iot-technologies
Ovo je bilo ukratko, ukoliko neko ima još informacija, neka me slobodno ispravi odnosno dopuni.
Moja pretpostavka je da će NBIoT pogurati mobilni operateri jer neće dozvoliti da im se uzima deo kolača. Pošto se ide preko njihove infrastrukture moraće da im se plaća. To sve naravno, ukoliko se trend nastavi. Načuo sam da VIP kod nas ima neku akciju po tom pitanju. LoRa podrazumeva da imate svoje gejtveje što košta. CISCO kao veliki igrač ima getvej za LoRa. Ovi Semtech moduli se najviše pominju u toj priči. Microchip ima svoj modul, ST takođe...
Nebojša, ja bio na dva Quectel seminara kod nas (Vitaelko i Comet) i nisam te video. Jesam li propustio neki? Kad je to bilo?
@gorankg
Apsolutno si u pravu.
Iz mogu ugla ovo nije nužno loše jer. Iskustvo sa LoRa tipom modulacije domet u gradu sa modulom koji je podešen na svega 200 bauda je imao maksimalni domet od 500m u urbanoj sredini. Antene su bile unutar kuća na trećem i drugom spratu. Položaj je morao da se "nanišani".
To znači da bazne stanice/gateway-i moraju da budu veoma gusto raspoređeni po gradu. Za ruralne sredine verujem da je situacija bolja.
Ako već postoji potreba za ovakvom količinom posrednih uređaja, čemu praviti više paralelnih infrastruktura. Sistem integratorima i klijentima je onda isplativije da zakupe SIM karticu za NBIoT modul i da "voze" Smile
Ranije sam radio sa mesh topologijom i to lepo radi sa malom količinom uređaja, (par desetina) a sleep modovi su "smrt" za ovaj tip topologije. Tako da je taj tip topologije sve manje prisutan.
Semtech je firma koja je kupila tehnologiju LoRa-e od Cycleo SAS tako da je sada vodeći po proizvodnji ovih čipova. Njihovi transiveri su u preko 90% LoRa modula. Čak i jeftine kineze kada kupiš imaju te čipove.
Ja sam probao neke kineze od VitaElka i to radi solidno, WT801. Ovi moduli imaju još jedan mod rada, a to je direktno poin-to-point pa je moguće komunicirati i direktno end-device to end-device, što po globalnom konceptu nije ideja, već sve ide preko end-device -> gateway -> server.
Takođe probao sam i ovo:
http://www.st.com/en/evaluation-tools/p-...rwan1.html
Radi očekivamo dobro i takođe za test postoji poin-to-point firmware.
Sve ovo sam samo "zagrebao po površini" radi nekog osećaja, edukacije da kada se ukaže potreba odmah uletim u neki projekat bez da lutam šta i kako. Nažalost do sada nisam ništa konkretno realizovao sa LoRa-om.
Što se tiče seminara, nisi ti propustio, ja sam... Sad Previše posla, pa retko kada stignem da odem na neki seminar. Sa druge strane prijatelji iz VitaElka/Cometa nas uvek imaju u vidu pa svrate sa inženjerima (FAE) do nas u firmi tako da nam približe novitete jer koristimo njihove module, čipove i slično.
Pre oko 10 godina sam sa kolegom Mladenom imao iskustava sa Zig Bee mrežom za uvezivanje nekih mernih uređaja. Naravno, pristojno je radilo kad ima relativno mali broj nodova i kad se češće budi iz sleep moda...
Izašli su nam u susret ljudi iz Vita Elko i dali na revers kompletnu razvojnu opremu oko Zig Bee.
Sve najbolje o Vita Elko.
Ne znam kako je kod vas ali ja i dalje svakog prvog u mesecu kačim na ulaznu kapiju papir sa stanjem mog električnog brojila i potrošnjom gasa ili vode. Onda neki čika ili teta zarede po ulici pa to učukaju u neki terminal. I to za svaku stavku posebno. Jedno, pa drugo, treće...
Inače, i od mene sve preporuke za Vitaelko.
Допунио бих са пар детаља. LoRa и чак LoRaWAN није толико далеко колико се чини на први поглед. Уз помоћ комуне могуће је направити своје апликације и повезати уређаје на отворену и бесплатну глобалну мрежу. Можете погледати њихов кратки рекламни видео и документацију:
https://www.youtube.com/watch?v=U4UrXl-SGEo
The Things Network - http://www.thethingsnetwork.org[Image: ici30G]
Покривеност у нашем региону није превелика али полако и сигурно напредујемо.
https://ibb.co/ici30G
На слици @1van је склапање једног гејтвеја yз помоћ iC880A концентратора.
Тренутни проблем је и цена самих уређаја. Верујем да ће цена ићи доле када браћа Кинези крену масовније.
Hvala Nenade na dopuni, korisna je.
Ako sam dobro video na mapi, postoji jedan u Nišu?
Kako mogu doći do informacija ko ga drži i da li je moguće napraviti neki test sa njim?
Ja sam sa kolegama firmi se malo "poigrao" sa LoRa-om, ali ništa ozbiljno. Testirao sam point-point komunikaciju. Naredni korak je trebao da bude end-point pa na neki gateway pa na server itd... Razmišljao sam da mi podignemo neki low-budget na RPy platformi, ali nismo postigli da dođemo do toga.
Uvek sam raspoložen za istraživanje, testiranje i slično. Naravno, koliko mi vreme dozvoli, jer živimo u vremenu kada je 12-16h radnih na poslu svakodnevnica Sad
Ако се не варам у питању је колега Душан Стојковић. Мислим да је се лако могли повезати са њим: https://www.thethingsnetwork.org/u/dusan
Још једна кратка допуна... ТТН ради тако што смо сви у једној глобалној мрежи. Тако да ће наши уређаји из Новог Сада радити и када смо у Нишу и обрнуто. Другим речима где год се ухвати ТТН сигнал на планети.
И ми смо у сличној ситуацији са временом. Али, воље увек има. Wink Ускоро ћемо се играти мало више...
Hvala, nadam se da ću uskoro postići da ga kontaktiram.
