Threads: 17
548
I kod mene radi sve kako treba.
Probaj u podešavanjima za mrežni adapter (žični ili bežični) da postaviš neki open DNS, tipa Google:
8.8.8.8
8.8.4.4
Threads: 72
1.599
07-24-2017, 12:00 PM
(This post was last modified: 07-24-2017, 12:01 PM by branko tod.)
Ljudi, glavno je da sam našao nalepnice. A računar mi je sređivao jedan naš drugar
Threads: 29
669
07-24-2017, 12:05 PM
(This post was last modified: 07-24-2017, 12:07 PM by Želja.)
(07-24-2017, 11:23 AM)branko tod Wrote: Zvao sam ih telefonom. Cena za 100 kom je oko 250 evra. Indikator ima 10 tačaka.
Nije baš ni jeftino, za papir jednokratne upotrebe ...
Threads: 132
3.539
07-24-2017, 12:08 PM
(This post was last modified: 07-24-2017, 12:09 PM by mikikg.)
Branko, ako te ne mrzi i hoces to da proveris sto ne otvara tu stranicu jer moguce da ce ti to i na drugim stranicama praviti probleme, probaj ove dve komande u terminalu tog racunara:
Code: ping optimexboje.com
To treba da vrati nesto poput:
Code: PING optimexboje.com (181.224.143.195): 56 data bytes
64 bytes from 181.224.143.195: icmp_seq=0 ttl=45 time=38.887 ms
64 bytes from 181.224.143.195: icmp_seq=1 ttl=45 time=37.922 ms
Druga komanda:
Code: tracert optimexboje.com
Ta komanda ce kod tebe drugacije da vrati rezultat ali zadnji red odgovora mora da bude sa IP adresom 181.224.143.195, tj negde oko 12. linije bi trebalo da imas iste rezultate.
Code: traceroute to 181.224.143.195 (181.224.143.195), 64 hops max, 52 byte packets
1 192.168.0.1 (192.168.0.1) 0.575 ms 0.364 ms 0.550 ms
2 10.65.0.1 (10.65.0.1) 7.486 ms 7.266 ms 13.929 ms
3 kg-he-m-1-pc3.sbb.rs (89.216.4.204) 6.334 ms 6.264 ms 8.358 ms
4 kg-he-m-1-pc-5.sbb.rs (89.216.9.174) 6.322 ms 7.348 ms 7.867 ms
5 kg-he-m-0-pc3.sbb.rs (89.216.9.16) 7.758 ms 6.497 ms 8.381 ms
6 bg-tp-m-0-hu5-0.sbb.rs (89.216.5.236) 15.185 ms 12.276 ms 15.420 ms
7 bg-tp-r-1-hu6-0.sbb.rs (89.216.5.254) 11.399 ms 10.730 ms 11.850 ms
8 be4995.rcr21.beg03.atlas.cogentco.com (149.14.236.1) 9.121 ms 9.728 ms 7.843 ms
9 be3269.ccr31.bud01.atlas.cogentco.com (154.54.59.193) 15.077 ms 16.721 ms 22.662 ms
10 be3263.ccr22.bts01.atlas.cogentco.com (154.54.59.177) 15.907 ms 18.276 ms 17.080 ms
11 be2988.ccr21.vie01.atlas.cogentco.com (154.54.59.86) 18.467 ms
be2990.ccr21.vie01.atlas.cogentco.com (154.54.59.94) 18.415 ms 17.996 ms
12 level3.vie01.atlas.cogentco.com (130.117.14.30) 17.628 ms 17.197 ms 18.104 ms
13 ae-1-3.ear1.amsterdam1.level3.net (4.69.153.186) 53.737 ms 44.530 ms 42.803 ms
14 giglinx-inc.ear1.amsterdam1.level3.net (213.19.196.54) 38.551 ms 42.604 ms 37.848 ms
15 essharedlxc1.sgvps.net (107.6.154.250) 40.195 ms 38.330 ms 38.009 ms
16 ip-181-224-143-195.siteground.com (181.224.143.195) 38.167 ms 37.973 ms 39.275 ms
Threads: 72
1.599
I nisu. Preko sam našao 100 kom za 135 evra.
Da vidim koliki je prevoz, pa možda uvezem.
Threads: 29
669
07-24-2017, 12:13 PM
(This post was last modified: 07-24-2017, 12:14 PM by Želja.)
(07-24-2017, 12:12 PM)branko tod Wrote: I nisu. Preko sam našao 100 kom za 135 evra.
A zašto ne koristiš ovako nešto:
http://www.elementa.rs/files/48923-a.pdf
Cena: 20 eura
Threads: 72
1.599
07-24-2017, 12:27 PM
(This post was last modified: 07-24-2017, 12:31 PM by branko tod.)
Miki, hoću predveče da probam. Odoh za Batajnicu i do Bocka.
Željo, jer ne mere. Mora da bude tajni detektor pregrevanja.
Kada dam na testiranje, da imam indikaciju da li ga je pregejao
sa zlom namerom.
Threads: 29
669
Aha, kapiram ...
Onda jedino te ili slične nalepnice.
Threads: 72
1.599
07-25-2017, 07:45 AM
(This post was last modified: 07-25-2017, 07:49 AM by branko tod.)
Bio sam do Bocka i popili smo po malu čašu piva i veliku čašu razgovora.
Ili možda po dva piva
Threads: 49
1.603
Branko se "prvi upisao u "listu" "ugošćenih"" , barem sa pivce...
I vrlo ugodno provedeno vreme u društvu drugara, prosto je proletelo...
Sledeći!
Threads: 77
1.643
Jbg. Zaboravio komšija da i mene povede...
Threads: 72
1.599
07-25-2017, 02:02 PM
(This post was last modified: 07-25-2017, 02:03 PM by branko tod.)
Ja pošao u 2 sata, kada roblje još uvek radi
Vodim te sledeći put, za neki vikend.
Threads: 72
1.599
Da li neko ima smd otpor 0,25 w od 1 mili om, bio bih vrlo zahvalan?
Threads: 132
3.539
Tesko se nalazi ta vrednost, 100mili ima, 10mili vec se teze nalazi, 1mili jos teze ...
Parce neke kantal zice bi pre moglo da zavrsi posao ...
Threads: 56
3.047
I turpijom doteraš vrednost. Možda možeš pokušati da malo zasečeš one 1206 jumpere...
Threads: 17
548
Ima u farnelu, ako nešto znači, verujem da stiže za 5-6 dana.
http://uk.farnell.com/c/passive-componen...e=0.001ohm
Threads: 72
1.599
07-27-2017, 07:51 PM
(This post was last modified: 07-27-2017, 07:53 PM by branko tod.)
Znam da ima preko, al ja da pitam dal ima neko.
Mogu precizno da izmerim do 4 moma, pa ću da od žice odradim 5 moma i onda odmerim šublerom 1 mom
Threads: 102
222
Jel ima neko iskustva sa 3D stampom? Imam neki model, za koji support nikako da ubodem... i iskreno vec mi dosta pokidao zivce
Ako neko ima iskustva nek javne pa da mu pustim STL i \ ili GCODE.
Threads: 132
3.539
Pitaj preko PM @bogdan.kecman oko 3D stampe ...
Threads: 102
222
Ok poslah mu PP, ako ima jos nekog ko ima iskustva nek se javi slobodno.
