#21
<p>Razmisljam gde da stavim ovu zezanciju. Nije za Hi-Fi, mada zvuci tako, a jos manje je za PA... Smile<br><br>
Kako glasi ona narodna izreka, ''besposlen pop i jarice krstava''... Tako i ja iz dosade pravim ove male gluposti, koje za divno cudo sviraju predobro za svoj kapacitet!<br>
Nadjem neki mali 4'' auto zvucnik i reko' ajd da sklepam kutijicu neku i probam!<br>
Kompresiona, napunjena sintetickom vunom, 18mm MDF....Necete verovati ali na mojoj test Yamahi AX-700 svira vrhunski Smile iznenadjen!</p>
<p>&nbsp;</p>
<p>Pozz majstori - Stojke!</p>
<p><img src="http://i783.photobucket.com/albums/yy116/promaxrs/babyspeaker5_zps53acb134.jpg" alt="babyspeaker5_zps53acb134.jpg"></p>
<p>&nbsp;</p>
<p><img src="http://i783.photobucket.com/albums/yy116/promaxrs/babyspeaker4_zps971a1acd.jpg" alt="babyspeaker4_zps971a1acd.jpg"></p>
<p>&nbsp;</p>
<p><img src="http://i783.photobucket.com/albums/yy116/promaxrs/babyspeaker3_zps31a17b05.jpg" alt="babyspeaker3_zps31a17b05.jpg"></p>
<p>&nbsp;</p>
<p><img src="http://i783.photobucket.com/albums/yy116/promaxrs/babyspeaker2_zps7fe2c714.jpg" alt="babyspeaker2_zps7fe2c714.jpg"></p>
<p>&nbsp;</p>
<p><img src="http://i783.photobucket.com/albums/yy116/promaxrs/babyspeaker1_zps7389b74f.jpg" alt="babyspeaker1_zps7389b74f.jpg"></p>
<p>Novi izumi :-)<br><br><br>
[attachment=1119Confusedasad-dvd.jpg][attachment=1120:noname18.jpg][attachment=1121:noname8.jpg][attachment=1122:noname7.jpg]<br><br><br>
Nastavak izuma:[attachment=1126:129167981632693649.jpg][attachment=1125:1291196862750333841.jpg][attachment=1124:noname.jpg][attachment=1123:noname3.jpg]<br><br><br>
i jos:[attachment=1130:129141264891787819.jpg][attachment=1129:129145307380390864.jpg][attachment=1128:129148019159627024.jpg][attachment=1127:129162650070211351.jpg]<br><br><br>
ima jos:[attachment=1132:129042365725304144.jpg][attachment=1131:129057438342972414.jpg]</p>
[attachment=1170:Fotografija-0104.jpg]
Nešto malo iz dosade...
[attachment=1171:Fotografija-0107.jpg]
[attachment=1172:Fotografija-0108.jpg]
<p>Evo i mog "svrce", kada se vec dotakosmo cevki. Pravili smo ga ortak i ja 92-3'. On kutiju, ja unutra.<br><br>
2 x 4W u A klasi. Po jedan potencijalni W (mogao bi i 2 x 5W) mu je "ukrala" veoma cvrsta globalna povratna veza kojom sam ispeglao transformatore, koliko se to moze.<br><br>
Neobicno dobar bas i visoki za cevasa u A klasi.<br><br>
Vec je prosao vojsku (po starosti). Prvih 50 godina mu necu menjati cevi, a drugih 50 cu da budem nagluv, pa ne moram ni onda :-).<br><br>
Usput, ima li neko EM80?<br>
Obe mi vec bledo svetle. Bio bih zahvalan ako neko iskopa bar jednu koja se dobro vidi.<br><br>
Ono sto je zanimljivo kod ove napravice je veoma jaka globalna povratna veza, i stabilizacija napona sa dva mosfet stabilizatora kaskadno.<br>
Takodje i "vumetri" sa magicnim okom EM80.<br><br>
Nema uopste uzemljenje, i moze se telegrafisati mreznim prekidacem dok svira, bez ikakvih cujnih efekata (osim skljocanja prekidaca).<br><br>
Zauvek ce biti kod mene...<br><br>
Ovo je spreda:[attachment=1173:Resize of IMG_2563.JPG]<br><br><br>
A ovo je sa g*zne strane:[attachment=1174:Resize of IMG_2564.JPG]<br><br>
Spopala ga prasina jer ga slusam samo zimi Big Grin<br><br>
Ima dve EL84 i ECC82 (ne 83 namerno).<br><br>
Kasnije sam probao A klasu sa PL84 koja ima drasticno nizu anodnu impendansu (EL84 5Kohm, a PL84 2Kohm).<br><br>
4 PL84 paralelno imaju impendansu od svega 500 ohm, gde je relativno lako na velikom jezgru namotati primar krstasto, cim se dobijaju mali parazitni kapaciteti i odlicni visoki, a veliko jezgro daje dobar bas.<br>
To jako lepo radi za tu vrstu i klasu pojacavaca. Sa jakom globalnom povratnom vezom moze dati oko 16W ciste snage po kanalu, ali zato trosi 300W i greje kao sporet Big Grin<br><br>
Steta je sto se PL84 veoma tesko nalaze. Opasna je to cevcica...</p>
Je*iga! Moj matori bacio dve kutije od cipela pune lampi dok je čistio garažu. Nije znao da sam ih ja tu uštekao za crne dane.
Bolelo....
Pre nekog vremena tražeći neke gluposti po ostavi naletim na uparene AD161/AD162. Baš me zanimalo kako zvuče. Dodao LM741 u TO-99 kućištu i ovako upakovao.
[attachment=1175:Fotografija-0121.jpg]
Šteta što nemam još jedan par, pa da to lepše rešim u stereo verziji.
Evo još jedna slika.
[attachment=1176:Fotografija-0122.jpg]
Inače ima neobično lep zvuk za takvog mališu.
<blockquote class="ipsBlockquote" data-author="tda" data-cid="1580" data-time="1365960161"><p>Evo još jedna slika.</p>
<p><br><img src="http://forum.diyaudioproject.eu/public/style_images/master/attachicon.gif" alt="attachicon.gif"><a href="http://forum.diyaudioproject.eu/index.php?app=core&amp;module=attach&amp;section=attach&amp;attach_rel_module=post&amp;attach_id=1176">Fotografija-0122.jpg</a></p>
<p>&nbsp;</p>
<p>Inače ima neobično lep zvuk za takvog mališu.</p></blockquote>
<p>Heh, lepa vremena behu kada se imalo vremena za igranje :-(</p>
Biće ih još...
Nisi toliko mator. Big Grin
<blockquote class="ipsBlockquote" data-author="tda" data-cid="1582" data-time="1365964796"><p>Biće ih još...</p>
<p>Nisi toliko mator. Big Grin</p></blockquote>
<p>Iskreno se nadam, no to nema veze sa mojim godinama vec sa opstim trendovima u svetu, koji mi ne mirisu na buduca najbolja vremena.</p>
Evo i od mene jedna spravica ... U pitanju je moj projekat i konstrukcija ZMSDR, digitalni SDR HF radio prijemnik (0.2 - 30MHz).
Iako mozda lici da nije vezano za audio temu ovde se debelo mesa high-perfomance audio tehnika Smile
Pocevsi od opakih low-noise OP-ova, preko ultra-low-noise naponskih stabilizatora, ultra-low-distorsion kondenzatora za integrator, low-ers decoupling, low-noise otpornika itd, pa sve do HD 192kHz / 24bit A/D konvertora (u mom slucaju TC Electronic Impact Twin) koji se koriste (externo) za ove spravice.
Prakticno sve je to audio "fazon" samo ja ulazni signal malo drugacije interpretiram tj demoduliram Wink
Oko digitalnog dela PIC firmware, USB driver, upravljanje low-jitter oscilatora, kvadradurnoj I/Q demodulaciji i sl. mogao bih da pisem nasiroko ali ajd da ostane na ovome.
Ovo sve radi na 3.3V (pravi podvig za mene a i ovu tehniku) i napaja se sa veoma prvljavih 5V USB sa racunara i sa ovom postavkom sam dobio oko 110dB dinamike (SFDR ~90dB) u nama cujnom audio opsegu Smile
[attachment=1177:zmsdr-v3-mcu.jpg]
<blockquote class="ipsBlockquote" data-author="Macola" data-cid="1576" data-time="1365955264"><p>Evo i mog "svrce", kada se vec dotakosmo cevki. Pravili smo ga ortak i ja 92-3'. On kutiju, ja unutra.<br><br>
Vec je prosao vojsku (po starosti). Prvih 50 godina mu necu menjati cevi, a drugih 50 cu da budem nagluv, pa ne moram ni onda :-).<br><br><span style="font-size:14px;"><strong>Usput, ima li neko EM80?</strong></span><br>
Ovo je spreda:<img src="http://forum.diyaudioproject.eu/public/style_images/master/attachicon.gif" alt="attachicon.gif"><a href="http://forum.diyaudioproject.eu/index.php?app=core&amp;module=attach&amp;section=attach&amp;attach_rel_module=post&amp;attach_id=1173">Resize of IMG_2563.JPG</a><br><br><br>
A ovo je sa g*zne strane:<img src="http://forum.diyaudioproject.eu/public/style_images/master/attachicon.gif" alt="attachicon.gif"><a href="http://forum.diyaudioproject.eu/index.php?app=core&amp;module=attach&amp;section=attach&amp;attach_rel_module=post&amp;attach_id=1174">Resize of IMG_2564.JPG</a><br><br>
Steta je sto se PL84 veoma tesko nalaze. Opasna je to cevcica...</p></blockquote>
<p>&nbsp;</p>
<p>Za ovo pojacalo po Kragujevcu prica ko god ozbiljno fura HiFi, naravno ako ga je cuo. Dakle, ja nisam cuo ovo pojacalce ali sam cuo za njega da je posramilo nesto veliko poput VTLa sa brdom KT88ica.</p>
<p>&nbsp;</p>
<p>Macola, mislim da imam neku EM80, ali sam ubedjen da ima EM84 javicu ti sutra kad proverim.</p>
<blockquote class="ipsBlockquote" data-author="BeliNinja" data-cid="1586" data-time="1365972812"><p>Za ovo pojacalo po Kragujevcu prica ko god ozbiljno fura HiFi, naravno ako ga je cuo. Dakle, ja nisam cuo ovo pojacalce ali sam cuo za njega da je posramilo nesto veliko poput VTLa sa brdom KT88ica.</p>
<p>&nbsp;</p>
<p>Macola, mislim da imam neku EM80, ali sam ubedjen da ima EM84 javicu ti sutra kad proverim.</p></blockquote>
<p>Ne mogu reci da je "posramio" stvarno mocnog VTL, jer to je retko cevno pojacalo koje radi skoro kao tranzistorsko i koje kada mu uguras cetvrtku na ulaz, skoro istu takvu i izbaci.</p>
<p>Taj VTL o kome pricaju tu "buvu" stvarno inzvaredno radi, posebno je dobro proradio kad sam mu uradio automatski bias, jer je stvarno problem na svakih par meseci podesavati&nbsp; bias za 12 KT88 ili KT90 cevi po kanalu.</p>
<p>Najgore je bilo to sto su (fabricki) ta podesavanja bila uzajamno zavisna i zavisila od ukupne temperature pjacavaca, pa je podesavanje oba kanala znalo da potraje citav dan.</p>
<p>Dodao sam mu unutra 12 servoamps sa IC, i resio automatski bias, onda je stvarno prosviralo jer je simetrija izmedju cevi bila perfektna (i naravno obezbedila njihov najduzi vek).</p>
<p>Neko je kupio tog VTL (bivsi vlasnik ga je prodao).</p>
<p>Ne znam ko ga je kupio, ali se nece pokajati. Sjajno to radi.</p>
<p>&nbsp;</p>
<p>Mali cevas je nosen na nekoliko mesta i nije nista porazio, samo su se malo izbecili kada su culi kako svirucka ta igracka.</p>
<p>Naravno ni priblizno kao dobar tranzistorski pojacavac, ali poprilicno dobro za svoju snagu i radnu klasu.</p>
<p>Verovatno su bili iznenadjeni sa 2 x 4W, posebno kada sm to prikacio na Infiniti "mrtvacke kovcege". DSvi sunekako imali utisak da se nece cuti nista, medjutim... 4W je 4W, ma odakle izasli Big Grin</p>
<p>&nbsp;</p>
<p>Ako nadjes dobru EM80 imas rucak u Maloj Avali Big Grin Kod Ane Big Grin</p>
<p>&nbsp;</p>
<p>Volim kad mi to zimi svetli i jos greje. Trosi &gt;50W za 2 x 4W Big Grin</p>
Obicno ljudi iz audio sveta ne zalaze na oglase poput ovog http://www.radista.info/oglasi/ ili http://www.drmilitary.com/
Tu ima da se upeca svasta-nesto, razne el. cevi, ispravljaci, konektori, kutije za uredjaje, polovni vojni uredjaji koji su prepuni fenomenalnih delova (za skoro svaki taj vojni uredjaj sad ima dokumentacija pa pre kupovine moze da se prostudira sta tacno ima unutra) ...
Možda nekom bude trebalo.
Ovde možete naći šeme skoro svih modela Microlab-ovih aktivnih zvučnika.
@Macola, na zalost samo jedna polovnjaca EM80, ne znam u kakvom je stanju. Koji je ruski ekvivalent njoj, 6E1P bese? Videcu da li ima kod Ivaila to. Imas li ti semicu tog tvog pojacalceta i motacki list izlaznih ako zelis da podelis sa nama? U poredjenju sa Kiticevim RH84, sta bi bilo bolje po tebi?
<blockquote class="ipsBlockquote" data-author="BeliNinja" data-cid="1692" data-time="1366065009"><p>@Macola, na zalost samo jedna polovnjaca EM80, ne znam u kakvom je stanju. Koji je ruski ekvivalent njoj, 6E1P bese? Videcu da li ima kod Ivaila to. Imas li ti semicu tog tvog pojacalceta i motacki list izlaznih ako zelis da podelis sa nama? U poredjenju sa Kiticevim RH84, sta bi bilo bolje po tebi?</p></blockquote>
<p>Ne znam sta je Kiticev RH84 (pretpostavljam neki pojacavac sa EL84)?</p>
<p>&nbsp;</p>
<p>Super za EM80! Probacemo, pa ako bolje svetli od ove moje slabije, stavicemo.</p>
<p>&nbsp;</p>
<p>Semu imam na nekoj papircini samo treba da je iskopam, a trafoi su od radija Melodija (takvi kakvi jesu :-).</p>
<p>&nbsp;</p>
<p>Lakse mi je da ga otvorim i skinem shemu nego da nadjem taj papir (ko zna gde je to?).</p>
<p>&nbsp;</p>
<p>Sta je bolje? Nemam pojma, nikad nisam cuo to drugo. Mozes napraviti ovo moje, super je jednostavno.</p>
<p>&nbsp;</p>
<p>Rasturis dva stara radija zbog mreznog i izlaznih trafoa, i sastavis onako kako nacrtam, za sat vremena, ne treba ti vise ako si mehaniku predmontirao.</p>
<p>Pa onda probaj kako radi i uporedi posto si cuo to drugo.</p>
<p>&nbsp;</p>
<p>Pozz</p>
he heee - e pa baš zbog toga nemam još ni jedan lamaški uređaj! treba li gledati neki određeni model(recimo Melodija XX ) ? to mi je želja već neko vrijeme ali se nisam udubljivao u problematiku baš zbog mrežnih i izlaznih transformatora.
Najbolji prijatelj.
[attachment=1230:212453_rusi-02--aleksandar-mihajlin_ff.jpg]
<blockquote class="ipsBlockquote" data-author="Macola" data-cid="1694" data-time="1366065689"><p>Ne znam sta je Kiticev RH84 (pretpostavljam neki pojacavac sa EL84)?</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>Pozz</p></blockquote>
<p>&nbsp;</p>
<p>Dogovor pao, kad budes raspolozen javi se na PM da se organizujemo.</p>
<p>Inace evo lik ovde prodaje novu ali opet jednu <a href="http://www.kupujemprodajem.com/NOS-macije-oci-lampe-EM80-EM84-5615166-oglas.htm?filter_id=22118926">http://www.kupujemprodajem.com/NOS-macije-oci-lampe-EM80-EM84-5615166-oglas.htm?filter_id=22118926</a></p>
<p>&nbsp;</p>
<p>Sto se tice RH84 evo semice, a nisam je ni ja slusao ali je popularna semica po svetu a nas covek je dizajner i ima celu gamu izmena na istu temu samo za drugaciju izlaznu cev RH807, RH88, RH KT90 mozda ima i jos koja. IIsta ulazna ECC81, samo se napajanje i izlazna menjaju i naravno prilagodjenje komponenti u okruzenju.</p>
<p>&nbsp;</p>
<p>[attachment=1234:rh84_sch.jpg]</p>
<p>&nbsp;</p>
<p>Ae, ako nadjes semu okaci je na forum pa da probamo nesto da napravimo.</p>
<p>&nbsp;</p>
<blockquote class="ipsBlockquote" data-author="HomeMadeAudioProject" data-cid="1700" data-time="1366096638"><p>he heee - e pa baš zbog toga nemam još ni jedan lamaški uređaj! treba li gledati neki određeni model(recimo Melodija XX ) ? to mi je želja već neko vrijeme ali se nisam udubljivao u problematiku baš zbog mrežnih i izlaznih transformatora.</p></blockquote>
<p>&nbsp;</p>
<p>Ma smislicemo nesto, ovi izlazni iz radio aparata su jednostavno motani, mozemo i mi nesto na tu foru da skarabudzimo.</p>
<p>Evo jos par stvarcica od&nbsp;imenjaka Aleksandra (Alex)&nbsp;Kitica.</p>
<p>&nbsp;</p>
<p><a href="http://rh-amps.blogspot.com/">http://rh-amps.blogspot.com/</a></p>
<p><a href="http://www.audiokarma.org/forums/showthread.php?t=437035">http://www.audiokarma.org/forums/showthread.php?t=437035</a></p>
<p><a href="http://www.tubeaudio.8m.com/Rpa/rpa.html">http://www.tubeaudio.8m.com/Rpa/rpa.html</a></p>
