Threads: 132
3.539
09-01-2014, 08:52 AM
(This post was last modified: 09-03-2014, 01:49 AM by mikikg.)
Posto ovakvu temu nismo imali jos uvek na forumu, startujem novu gde bi bilo fino da postavimo linkove do korisnih knjiga iz oblasti tehnike i elektronike, domaca i strana, stampana i elektronska izdanja.
PS: Molim da se vodi racuna o autorskim pravima, bez linkova na "warez"!
PS2: Za rok vazenje autorskih prava pogledajte ovaj link:
http://en.wikipedia.org/wiki/List_of_cou...ht_lengths
Threads: 132
3.539
09-01-2014, 08:57 AM
(This post was last modified: 09-01-2014, 09:07 AM by mikikg.)
Threads: 132
3.539
09-01-2014, 09:01 AM
(This post was last modified: 09-01-2014, 09:08 AM by mikikg.)
Za mikrokontrolere, solidna knjiga za pocetnike
Programski jezik C za PIC mikrokontrolere III štampano izdanje
http://www.infoelektronika.net/knjiga/n=pic-c
Jos jedna odlicna knjiga, englesko izdanje od autora Joseph Yiu
The Definitive Guide to ARM® Cortex®-M3 and Cortex®-M4 Processors, Third Edition
http://www.amazon.com/Definitive-Cortex...0124080820
Threads: 6
24
C programski jezik, Autori: Brian W. Kernighan; Dennis M. Ritchie
http://www.cet.rs/index.php/knjige-2/pro...etail.html
Threads: 77
1.643
Bravo za temu!
Threads: 6
24
09-01-2014, 05:25 PM
(This post was last modified: 09-01-2014, 06:42 PM by TDA.)
(09-01-2014, 10:18 AM)buca33 Wrote: Koristice onima koji tek pocinju da proucavaju rad SMPS-a
http://worldtracker.org/media/library/**...******.pdf Mala napomena, mislim da je ovo piraterija (pošto ima da se kupi na Amazonu), čisto da forum nema problema sa tim, dovoljan je samo autor i naziv, a ko želi može da nadje "iz prve".
Threads: 133
523
09-01-2014, 05:30 PM
(This post was last modified: 09-01-2014, 05:34 PM by HomeMadeAudioProject.)
dijelim mišljenje imenjaka,nisam siguran ali imam sumnje... bilo bi dobro kad bi imali načina da proverimo jeste/nije piraterija prije neko objavimo link,da li neko zna kako to uraditi - postoji li način?
ovo što je mikikg objavio sigurno nije piraterija, od njih sam kupio knjigu o prelidačkim napajanjima i vjerujte da vrijedi sve i dinar,a ni poštarinu nisam platio već je bila o njihovom trošku.
svaka preporuka,i vjerujem da će mi sledeći pazar kod njih biti baš ova nova o operacionim pojačavačima!
Threads: 6
24
09-01-2014, 05:51 PM
(This post was last modified: 09-01-2014, 06:05 PM by azecevic.)
InfoE radi svoje knjige i prevodi (to ne mogu da tvrdim da imaju dozvolu, ali je verovatno imaju), Mr. Radojle Radetić verovatno ima saradnju sa njima i to su provrene knjige. Takodje sam od njih pazario Prekidačka napajanja i vrlo verovatno ću i ovo o operacionim pojačavačima.
Mislim da je najlakši način da se proveri da li je nešto piraterija ili ne je videti da li se ta knjiga prodaje kod većih svetskih distributera. Koga zanima verovatno će i sam naći, čisto da forum nema problema oko toga.
@buca33 Ništa lično, siguran sam da si ovo postavio iz najbolje namere.
Sad vidim da ova stranica u opisu kaže da postavljaju legalne stvari, kao otvorena biblioteka, pojma nemam, što li onda na Amazonu to prodaju (doduše deluje kao novije izdanje).
Threads: 77
1.643
Postovi #5 i #7 su trenutno sakriveni dok ne utvrdim da li spadaju u kršenje autorskih prava.
#5 je sporni link koji je buca naveo, a #7 je azecevicev komentar u kojem je naveden i bucin post pa sam morao i njega da sakrijem.
Sve je tu i biće vraćeno u najkraćem roku.
Hvala na razumevanju.
Threads: 77
1.643
09-01-2014, 06:39 PM
(This post was last modified: 09-01-2014, 06:41 PM by TDA.)
Žao mi je ljudi.
U knjizi stoji ova napomena:
Quote:No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photo-copy, recording, or any information storage and retrieval system, without permission in writing from the publisher.
Post #7 vraćam bez linka koji je Buca naveo.
Izvini Buco. Znam da si imao najbolju nameru.
Threads: 6
24
Practical Switching Power Supply Design, Autor: Marty Brown
I vuk sit i ovce na broju.
Ne bi bilo loše da se u prvi post ubacuju navedene knjige, jer će se tema vremenom napuniti i biće teško da se išta nadje, ovako bi moglo recimo da se sortira u neke kategorije (napanja, pojačala, primenjena elektronika itd.).
Threads: 77
1.643
Hvala Zečeviću. Nije nezakonito objaviti ime knjige.
Ideja ti je dobra. Prepustiću da mikikg edituje svoj post ukoliko želi.
Threads: 133
523
09-01-2014, 08:04 PM
(This post was last modified: 09-01-2014, 08:22 PM by HomeMadeAudioProject.)
http://www.trafco.rs/tubeaudio.php
obratiti pažnju na donji dio stranice sa linka:
Quote:Knjiga:
Ir. Menno van der Veen
Savremena High end Cevna Pojačala zasnovana na
torusnom izlaznom transformatoru
- Obrtač faze (download1.pdf)
- Od 10 do 100 Wati (download2.pdf)
- Mrežno napajanje (download3.pdf)
- Gitarsko pojačalo sa torusnim izlaznim transformatorom(download4.pdf)
- VDV-6AS7 (Maurik) (download5.pdf)
Knjiga:
High end Cevna Pojačala 2
- DC-Blocker (download)
- Gitarsko pojačalo 40W74-2 (uskoro)
- Mini triodni pojačavač MTV-10(uskoro)
- Le Miracle (uskoro)
- Super pentodno/super triodno pojačalo SPT-70(uskoro)
101 Outer Space
Projects for the
Evil Genius
DAVE PROCHNOW
magistarski rad Ivan Đurek kakvoća izlaznih audio pojačala snage
Threads: 132
3.539
Jedna fenomenalna kolekcija aplikacinih nota od Linear-a, to vredi svaku ponaosob makar prelistati da se vidi sta sve ima pa se "prisetiti" kad zatreba
http://www.linear.com/designtools/app_notes.php
Threads: 132
3.539
Threads: 133
523
" InfoElektronika 118
Na ovaj dan pre tačno 19 godina
izašao je iz štampe prvi broj časopisa
InfoElektronika. Svim vernim
čitaocima zahvaljujemo na ukazanom
poverenju. U to ime broj 118 naći će
se u slobodnoj prodaji po posebnoj
ceni od samo 250 din koja je niža od
samih troškova izrade časopisa.
Svim pretplatnicima casopis ce biti
poslat u periodu od 5-8. Septembra,
dok ce u slobodnoj prodaji biti od
12. 9, 2014 god.
Medjunarodne pretplate poslate su
5.9.2014 god.
Pretplatnicima kojima je istekla
pretplata sa brojem 117, casopis
nadalje saljemo otkupninom dok nam
se citalac ne odjavi sa slanja.
Pretplatite se!
Pozivamo vas na pretplatu, cime ste
zasticeni od promene cene, a i
usteda je velika. Cena pretplate sa
postarinom za 6 brojeva je 1650 din
(259 din/kom), a za 12 brojeva
pretplata iznosi 2950 din (238 din/
kom).
Uz pretplatu na 12 brojeva dobijate
besplatno knjigu Eko elektricni kucni
sistem ili Cevni projekti.
U cenu pretplate uracunata je
postarina.
Zabavni LED projekti
Iskoristite ovu knjigu da izradite ove
projekte i vidite kako rade. Da bi Vam
se olakšao početak, svaki projekt ima
kratko objašnjenje, električne šeme i
fotografije. Imate besplatnu podršku
na Elektorovom web-sajtu sa nekoliko
veza na video snimke koji još lepše
prikazuju projekte.
Ne treba nam više nego da znate
Omov zakon.
Raspberry Pi
Knjiga sadrži koncizan uvod u Linuks
operativni sistem, posle čega ćete
početi da programirate u Bash-u,
Python-u i Javascript-u. Naglasak je
na Python-u i u većini slučajeva uz
kratka objašnjenja da bi shvatili
suštinu, tako ga brzo usvojite i
prilagodite svojim potrebama. Kad
sve podesite možete krenuti sa 45
projekata opisanih u knjizi.
RPi kuvar za Python programere
„Raspberry Pi kuvar za Python
programere“ je praktičan vodič za
dobijanje maksimuma od malog
računara koji se zove Raspberry Pi.
Ova knjiga sadrži brojne savete za
upotrebu Raspberry Pi-a i prikaz
najboljeg što on ima da ponudi,
predstavljajući detaljne Python 3
primere koje možete da naučite i
proširite; videćete gde će vas odvesti
vaša kreativnost!
PRENOS PODATAKA
ISM USKOPOJASNIM RADIO
MODULIMA
sa primerima
ISM uskopojasni radio moduli su
zbog niske cene, jednostavne
primene, dobrog dometa, malih
dimenzija i male potrošnje električne
energije našli veoma široku primenu.
Koriste se za daljinsko otvaranje/
zatvaranje vrata, daljinsko upravljanje
robotima, prenos podataka u
industrijskim postrojenjima itd."
Threads: 56
3.047
09-08-2014, 01:10 PM
(This post was last modified: 09-08-2014, 01:25 PM by Macola.)
Knjige koje preporučujem.
Napisaću naslove onako kako će ih čika gugl naći:
Analog Electronics Circuits, Systems and Signal Processing -autori D.Crecraft and S.Gergely
Designing Analog Chips -autor Hans Camenzind
Electrical and Electronic Principles and Technology -autor John Bird (izuzetno korisna knjiga za početnike ili učenike iz oblasti)
POWER ELECTRONICS HANDBOOK -autor MUHAMMAD H. RASHID
mjerni_pretvornici_u_procesnoj_industriji -autori Ratimir Žanetić i Renato Stipišić
New Views of the Solar System.pdf (izuzetno zanimljivo i ako nije vezano za forum)
Power Semiconductor Applications Philips Semiconductors (izuzetno dobro napisana)
Radio_prirucnik_za_amatere_i_tehnicare_dr_Bozo_Metzger_1985_cetvrto_dopunjeno_izdanje.pdf (to mora svako ko je uhvatio za lemilicu da ima u zbirci)
Compiled Tips ‘N Tricks Guide -Microchip
Agilent Technologies Impedance Measurement Handbook
The Secret of the Mastering Engineer -autor Bob Katz (neke važne tajne dobrog zvuka)
Threads: 29
3.186
(09-08-2014, 01:10 PM)Macola Wrote: Knjige koje preporučujem.
Jedna mala dopuna podataka o gornjoj publikaciji, tj. njeno aktuelno izdanje:
Bob Katz: Mastering Audio: The Art and the Science, Focal Press, 2007.
Pošto imam utisak da na forumu dominiraju "snagaške teme", evo i jedne reference za slabe signale:
Douglas Self: Small Signal Audio Design, Focal Press, 2010.
Vrlo korisne analize izobličenja pasivnih elemenata (napr. kondenzatora), temeljne analize šuma svih poznatih opamp-ova, sve praćeno simulacijama (LTSpice) i merenjima (čovek ima AP SYS2722).
Koga interesuju mikseri, naći će u knjizi gomilu informacija.
Threads: 28
65
09-15-2014, 11:07 AM
(This post was last modified: 09-15-2014, 11:09 AM by djera.)
mislim da ova knjiga zasluzuje da bue u prvom postu
p.s. obzirom da je scribd.com objavljena, predpostavljam da je ok da kopiram link ovdje. na sribd-u je vec preko godinu dana, od kada sam je pronasao tu gdje je i sada
http://www.scribd.com/doc/82805575/Mala-...no-Izdanje
Threads: 11
324
09-21-2014, 08:01 PM
(This post was last modified: 09-21-2014, 08:25 PM by enaB.)
Vežbe i predavanja iz predmeta Audioelektronika (vežbe), (predavanja) - pošto je kraj godine stranica je trenutno malo zatrpana, ali ima tu 8 tekstova vežbi sa 5-25 strana teksta na svaku temu (ne "prilog" nego vežba sa naslovom), naslove vidite i sami. U predavanjima su iste teme+pojačavači u D klasi, možda malo opširnije. Svakako preporuka za pogledati
Eric Bogatin: Signal and Power Integrity - Simplified (2nd Edition) - malo opširnija knjiga što se tiče broja strana, ali su bez mnogo komplikovanja objašnjeni otpornost, kapacitivnost, i induktivnost kao primarni i neželjeni parametri pasivnih elemenata i vodova (PCB pre svega), impedansa vodova i kako to sve deluje na električne signale koji kroz njih prolaze (uključujući i napajanje)
David L. Jones: PCB Design Tutorial ( link)- opšte smernice za početnike u crtanju štampanih ploča
Henry Ott: Noise Reduction Techniques in Electronic Systems [2nd Edition, 1988 Wiley & Sons ] - nisam čitao ali sam prelistao i rekao bih da ima zanimljivih stvari za čitanje i dosta crteža
